TT-01 Track Width
TT-01 Track Width
I've read that the track width of the tt-01 is quite narrow and some are increasing the track width by using the long wheel axels and oversized hexes while others are simply using larger hexes and offset rims. Can someone please enlighten me as to what the top racers are doing and how it affects handling and performance. Thanks.
The TT01 really isn't a high performance chassis so I don't think to many people are spending alot of money to make any major alterations. Changing axle lengths wouldn't change anything by itself. To adjust track width either offset hubs or offset wheels would do the trick. The hubs are your best bet to start with. Depending on what kind of racing you're doing, offset wheels may be useful or not. Remember that most 24mm racing wheels probably won't be available in various offsets. 0-2 degrees is most likely. 26mm wheels can be found in various offsets but keep in mind that most racing classes specify 24mm tire use. Hope that helps. The TT01 is a GREAT spec racing chassis.
Basically, I've read that some drivers feel that the car is too narrow and have chosen to use the long axles with the oversized hubs and want to find out more about how prevalent this is with other TT01 racers around.
Wow, did not know that. I guess I'm a little behind in my tt01 knowledge. Good to know. Thanks
