I need a suggestion for a 19Turn motor. >
Old 07-23-2004, 08:10 AM
  #31
etzkev's Avatar
Isn't that thing an "outlaw" because it is a quad magnet? Or is there anything else that makes it not legal?
-Kevin
etzkev is offline
Old 07-23-2004, 08:38 AM
  #32
AdrianM's Avatar
As mentioned before it is hemi wound(not cross wrapped) and It dosent have the ROAR mandated stepped shaft sticking out of the endbell side. Those two things keep it from being legal.
AdrianM is offline
Old 07-23-2004, 09:21 AM
  #33
etzkev's Avatar
Oh, Ok thanks. I didn't know it was hemi wound and it doesn't have the "stepped" shaft.
Thanks,
Kevin
etzkev is offline
Old 07-24-2004, 12:53 PM
  #34
ATLAS COPCO's Avatar
These purple springs can they be trinity ones
I have noticed that they will only fit one side of the end bell ,I may have to move the spring mounting point to where the brush heatsink is
ATLAS COPCO is offline
Old 07-24-2004, 01:26 PM
  #35
EddieO's Avatar
You have the EPIC stock springs. What you need is two of the regular springs. Epic stocks have the spring posts on the same end of the endbell....which requires a special spring for one of the sides.
I have the regular springs for $1 a pair if you need them or any good hobby shop could get them, just tell them you want the modified trinity springs, not the stock.
Later EddieO
EddieO is offline
Old 07-24-2004, 02:12 PM
  #36
Thanks i got some today and there was 6 pairs and i managed to sort it out ,so im going to run it with 766 and purple springs is that the way to go , what should i expect lot of rpm or grunt out of the corner Thanks edd
Old 07-24-2004, 07:05 PM
  #37
mwcet8k's Avatar
Question for anyone who knows the answer: Why does it matter if the armature shaft is tapered? I can't figure out why this is required by ROAR.
mwcet8k is offline
Old 07-24-2004, 07:47 PM
  #38
etzkev's Avatar
Just so it is easy and fast for them to verify that the armature is legal. It has nothing to do with performance.
-Kevin
etzkev is offline
Old 07-27-2004, 08:35 PM
  #39
OK for this Roar race I choice a Chameleon 2 (sp).
Can someon give me some spring/brush recomendations...
Thanks....
And how far off should i gear a 19T compared to a stock?
Smalls is offline
Old 07-27-2004, 09:01 PM
  #40
DavidAlford's Avatar
Trader Rating: 32 (100%+)
I've been running 19t for a few weeks now and I really like the Reedy quad mag motor. Once I got the gearing nailed it was just as fast as a C2 but felt like it have a little more rip out of the corner. For a C2 I've been running purple springs with high silver brushes. Fast but needs to be cut every two runs. The quad mag seems to last awhile between cuts.
DavidAlford is offline
Old 08-01-2004, 07:15 PM
  #41
Is this the Quad Magnet motor you guys were talking about? Is this legal for 19T spec Roar?
http://www2.towerhobbies.com/cgi-bin...&I=LXFBH5&P=ML
Smalls is offline
Old 08-01-2004, 07:31 PM
  #42
also...
I have a 19T arm that does not have the taper at the end and is missing the tag, its brand new.... what are my chances of using it at this roar race... just curious... sorry for so many questions.
Smalls is offline
Old 08-01-2004, 07:58 PM
  #43
mwcet8k's Avatar
Yeah, that's it. Not sure if it's legal or not. It's weird, even ROAR doesn't always follow their own rules regarding 19t spec. I think their rules state that the motor can't have ball bearings, but at the recent on road nationals the Reedy motor with bearings was the handout.
mwcet8k is offline
Old 08-01-2004, 07:59 PM
  #44
etzkev's Avatar
Well, you wont be using any motor you buy outside that race (from a hobby shop or whatever) to run at a Roar race, because they give handout motors and include the motor in the entry fee.
And yes, that is the correct motor.
-Kevin
etzkev is offline
Old 08-01-2004, 08:02 PM
  #45
etzkev's Avatar
Originally posted by mwcet8k
Yeah, that's it. Not sure if it's legal or not. It's weird, even ROAR doesn't always follow their own rules regarding 19t spec. I think their rules state that the motor can't have ball bearings, but at the recent on road nationals everyone ran the Reedy motor with bearings.
Well the thing is, as long as it is the handout, and everyone is using it, the rules don't apply. Roar can give whatever they want...it doesn't have to be legal...as long as everyone gets the same motor.
-Kevin
etzkev is offline
