Building a spool ? >
Building a spool ?
Building a spool ?
Old 07-23-2004, 01:00 AM
  #16
If you guys just try and shoe-goo some outdrives & pulley/gear together SOMETHING WILL BREAK
Have seen it happen twice
The Black Kat is offline
Old 07-23-2004, 01:16 AM
  #17
Hi Guys
Can i know that the spool we install whether is on the pro4 front gear box or the rear gear box???
Newbies is offline
Old 07-23-2004, 01:26 AM
  #18
Spool is for the front
Always keep a ball-diff in the rear of your electric vehicles regardless of what you use up-front
Hope that helps
Old 07-23-2004, 01:43 AM
  #19
Thank you! the black kat
but i don't really undertsand the way you guys make the spool, can anyone try to explain it more detail, because i am slow learner.
Thank you!
Newbies is offline
Old 07-23-2004, 03:13 AM
  #20
acutts's Avatar
Have just tightened it up .. no goo necessary and its just for testing really until the HPI one is released ....!
Nothing will break unless you hit something ...
acutts is offline
Old 07-23-2004, 06:44 AM
  #21
hobbipro's Avatar
Trader Rating: 23 (100%+)
Newbies, take a ball diff apart. Remove the D-rings (big silver washers that the balls in the gear touch and make a little groove) clean them up, and get a piece of cardheader (the small cardboard piece that usually comes stapled on the top of a R/C part with the item name/description on it) now glue this cardheader piece to the D-rings (both), let dry. After dry trim the card to the same shape and size as the ring (should be easy with it glued on) next remove all diff balls out of the gear only! You do not need to remove the thrust washers or bearings. Reassemble with the cardheader facing the gear (both D-rings), and reassemble and tighten the diff bolt till it is almost completely tight.
What this makes is essentially a slipper clutch, but you dont want it to slip until it needs to. I like this idea better than the full blown spool since this can break loose if you hit the pipes under power, saving your drive shafts and outdrives, and gears if you have a shaft car.
hobbipro is offline
Old 07-23-2004, 01:40 PM
  #22
crimson eagle's Avatar
Is a spool better than a one way? Or is this all because your home tracks don't allow one ways?
crimson eagle is offline
Old 07-23-2004, 02:00 PM
  #23
Trader Rating: 17 (100%+)
its different. Right now spools apear to be the latest hot thing. At the nats I know hara and many ohters ran them.
Kave is offline
