Motor does not spin smoothly >
Old 07-19-2004, 04:22 PM
DOMOisCOOL's Avatar
Red face Motor does not spin smoothly
I just rebuilt my Monster Stock motor (cleaned it out), and after I put on the endbell, the arm doesn't seem to spin smoothly anymore. But when I take off the endbell, it spins normally. I put the Monster endbell on my P2K Pro and the arm spinned smoothly. I can't figure out what's wrong
DOMOisCOOL is offline
Old 07-19-2004, 04:24 PM
Do you have too many shims on the arm?
AE Racer is offline
Old 07-19-2004, 04:26 PM
DOMOisCOOL's Avatar
I think I might. It doesn't have any slop. I didn't add any shims though.
Old 07-19-2004, 04:31 PM
s2
s2's Avatar
could be one of the magnets loose or even warped , have you got the motor very hot??
s2 is offline
Old 07-19-2004, 04:38 PM
DOMOisCOOL's Avatar
The motor has not been over heated.
I found out it's not the shims either. It may be the bushings or something. Because I took out both shims and felt if there was any play. There was none whatsoever. Then I tried to push the arm up and down to check the play again. When I pushed hard, it moved. Could it be the endbell bushing?
Without the endbell on, I pulled the arm up and down. It went freely. So bottom bushing/magnets should be alright.
Old 07-19-2004, 04:39 PM
Default too tight
if you just rebuilt the motor chances are that the end bell ring is bent . try to flatten it out and make sure every thing is lined up .. and make sure the bushings/ bearings are lined up ..
mb racer is offline
Old 07-19-2004, 04:48 PM
DOMOisCOOL's Avatar
Thanks for the help guys.
Found out it was the can bushing. I swapped my P2K and Monster Stock bushings and it was the problem. Now I gotta polish the original P2K bushing.
Any tips on polishing bushings? How to guide?
Thanx
Old 07-19-2004, 04:55 PM
s2
s2's Avatar
http://www.motortuningsecrets.com
check the stock motor section
s2 is offline
Old 07-19-2004, 05:16 PM
fatdoggy's Avatar
Polishing bushings - I cut a Q tip in half(add polish to the Q tip), stick one end through the bushing and then chuck into a drill, keep pressure on the Q tip till it passes through the bushing. I usually keep the bushing in the motor. Usually takes alot of Q tips to get it done, but it works.
fatdoggy is offline
