Noise when reversing using Front One Way Diff on TB-03 >
Old 11-22-2010, 03:47 PM
Strontium77's Avatar
Default Noise when reversing using Front One Way Diff on TB-03
I just set up a TB-03 with a front one way diff (using 9T EZRUN Brushless) and when I hit reverse the one way diff makes a screeching noise. Is this usual or do I need to adjust some of the spacing?
Also it seems to lack some breaking, this is the desired effect I am assuming?
Strontium77 is offline
Old 11-22-2010, 04:05 PM
sosidge's Avatar
I wouldn't expect any particular noise from a one-way. The lack of brakes is normal though.
sosidge is offline
Old 11-22-2010, 04:25 PM
Buckaroo's Avatar
The screeching noise is often from bearings lacking lube!!!!
As noted already, one of the side effects of a one way is a lack of brakes on that end!
Buckaroo is offline
Old 11-22-2010, 08:37 PM
Toh WL's Avatar
u try open the 1 way diff, use a tissue paper to wipe. u be surprised... just clean it & use the serpent 1 way lube to service.
Toh WL is offline
Old 11-23-2010, 06:15 PM
Thanks all.
