help with tamiya tb02 front end >
Old 11-26-2010, 05:57 PM
Default help with tamiya tb02 front end
i'm trying to repair my tamiya tb02 front end my wheel had fallen off and i had to replace the driveshaft because i lost it no my wheels have like a lot of play in them by play i mean that i can take my hand and shake the wheel and my drive shaft wants to fall back out i'm trying to find out what is the parts called or is there a place where i can like get a blueprint type thing or anything to help me thanx i have pics of the front end as attachments
Attached Thumbnails help with tamiya tb02 front end-imag0153.jpg   help with tamiya tb02 front end-imag0154.jpg
cdog2508 is offline
Old 11-26-2010, 06:03 PM
Digit09's Avatar
does the other side have the same problem? if not, compare the two for missing parts.
Digit09 is offline
Old 11-26-2010, 07:52 PM
Super Moderator
Grizzbob's Avatar
I think this will get a better response in the OnRoad forum, so I'll move it there, should be more people with personal experience with Tamiyas....
Grizzbob is offline
Old 11-28-2010, 06:13 AM
Azr
Azr's Avatar
I think you lost your upper king pin.
Azr is offline
Old 11-28-2010, 06:43 AM
Trader Rating: 24 (100%+)
Maybe the manual will help.
http://www.tamiyausa.com/pdf/manuals/58338ml.pdf
Don't worry if it's not the same body and kit number. A TB02 chassis is the same whether it's a Subaru or a Mercedes. The Aluminum parts on your car are add ons. The original parts are supposed to be plastic. Unfortunately that means some screw sizes (usually the length) might be different for your car but at least you know what things are supposed to look like. Good Luck
Evoracer is offline
