integy indy booster2 help >
Old 07-18-2004, 11:10 AM
hogdaddy77's Avatar
Default integy indy booster2 help
got one.and it has no instructions...does it matter what polarity goes where...and for 3300's I should not leave them on for over 5 minutes..right?
hogdaddy77 is offline
Old 07-18-2004, 11:33 AM
SalvadoriRacing's Avatar
the unit is bipolar.....simply put the cells on the tray.......
you can discharge niMH until the light bulbs go dim, the diacharge rate is low, only 1.75amps.....don't worry about deadshorting by leaving the cells too much time on the tray....
SalvadoriRacing is offline
Old 07-18-2004, 06:43 PM
protc3's Avatar
you can leave them on as long as you like,they cut off at 0 Volts without reversing the cells.
protc3 is offline
Old 07-19-2004, 05:13 PM
hogdaddy77's Avatar
thanks
