A good low-profile servo? >
Old 07-17-2004, 11:09 AM
I recently picked up a Yokomo SD with the Rayspeed conversion, so the servo is now mounted with the chassis, instead of perpendicular with the stock one. Anyways, space is a premium, and I can't seem to fit everything with a normal-sized servo. So I was looking to get a low-profile one. Any recommendations on a decent servo that is also affordable? (I already run a KO2123 btw)
I found this one and it's pretty cheap: http://servocity.com/html/hs-77bb_low_profile.html
Any comments would help, thanks.
micros_rock is offline
Old 07-17-2004, 11:19 AM
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
That has 1 metal and 4 plastic gears, say bye-bye to those in the right collission. I suggest the Futaba S9550, I use one in my XXXS and never had a problem with it. They are pretty affordable as well, you can propably find one for around $80, a lot less than other high-end digital servos.
Randy Caster is offline
Old 07-17-2004, 11:31 AM
Is the Hitec one really going to break that easily? I mean, there is a servo saver on the car. Or no go?
Old 07-17-2004, 11:43 AM
Trader Rating: 14 (100%+)
Mircos:
Hi,
You'll be alot better off with the 9550 servo. I have tried the HiTec servo and was not happy with it.
TimXLB is offline
Old 07-17-2004, 12:59 PM
Wency_TA03R-PRO's Avatar
Thumbs up
3 of my r/c buddies switched back to futaba 9550 servo from using hitec servo on their cars.. Futaba one of the great manufacturer of servo wether analog or digital ones..
Wency_TA03R-PRO is offline
Old 07-17-2004, 01:08 PM
howard hudson's Avatar
S9550 !!!
is the one to get very smooth and dependable
howard hudson is offline
Old 07-17-2004, 11:43 PM
lem2's Avatar
Originally posted by howard hudson
S9550 !!!
Simply the Best!!!!
lem2 is offline
Old 07-18-2004, 12:31 AM
Don't go Hitec...
Haven't tried any of Fruitaba's stuff yet but I hear good things about it....
They make nice looking chargers too
The Black Kat is offline
Old 07-18-2004, 02:02 AM
lem2's Avatar
Default Look. . . .
how small, and hope this helps you decide on what servo to use!!!
lem2 is offline
