Mantisworx F1 chassis!! sneek peek
Getting closer and closer! Here is the version that will be tested this week. Dimensions are where i want them i am still undecided on upper deck material and side shocks. some of the features:
Thin but strong carbon composite lower deck (30%stiffer than weaved carbon)
true link rear suspension with center ball pivot
droop adjustable shock position (dont have to add spacers to the inside of your shocks!!)
super stiff motor mount plate
proven tri-shock design
You should put the center pivot on the same axis as the pivots of the outer links. If not, you have a lot of binding when compressing the center shock.
not so much top secret but it does make a difference in the geometry, the rear is VERY planted and you can drive the car aggressively with confidence. it will accept 103/104 front suspension but is designed to keep the battery down the middle which eliminates the possibility of short wheelbase for the 103.
if you put the links on the exact same pivot point as the center pivot the links do absolutely nothing except keep the pod square. this design actually allows you to alter the rear suspension by way of the links ie IC. you can plant the rear end more for low traction by using longer links or raising the front balls or if you want more rotation go to the shorter links and move them back. it is a true link design and very tuneable. this is the third prototype i have made and there is no binding within the range that the suspension is moving which is about 2mm anyway max and normally not even that much.
Not to be a downer...but all the talk earlier was of an independent rear suspension with direct drive. This is another link suspension of which there are several already. It may or may not work better than other link suspensions...that is beside the point. I was expecting something different is all.
Also that pic doesn't really apply as that is a 4 or 5 link type suspension rather than one that pivots around a central pivot. The idea is similar but not the same.
It is very simple. Draw 2 dots on a piece of paper. Fold it and meaure the distance when the paper is flat and when you fold it a little. The distance between the dots will become shorter. Put a link there and the pod can't move up or down. Only the slop will allow you to do that.
Now the links on a link car always fight eachother a little bit when you rotate the pod sideways in extremes. In our application it is hardly noticable but it still does it. You have made the links so they bind the up and down movement as well. It could be considerd a tuning aid but i rather would try to do something with the center shock.
Just some positive critticism.
edit. If you would want to use that in a 3 link type suspension like john stranahan then it might work
i am a 40yr old engineer and i understand what is happening , i use autocad for all of my designs and everything is worked out, what both of you say is true but never the less the system works a hell of alot better than the traditional t plate system. how much do you think the suspension actually moves in a race situation? i have that data and its not very much at all, and definately not enough to "bind" the pod up. have any of you seen or felt the slop in any TC?? There is no more slop in this design than any other RC car. slop in this scale is something that you cannot get away with. the slop in the pod is only .015" , human hair is anywhere from .005 to .010" so lets keep the "slop" in perspective!!as far as the independent F1 stuff , it is coming but its interesting how when we talk about that nobody wants to change but if i design a traditional type chassis then everyone wants the IRS!! i cant make everyone happy but i figure its a much easier transition if i design a better system for the traditionalist first and the branch into the IRS since it is waaaaaay more involved and waaaaay more costly to produce and prototype.
i realize that the attached picture i posted is not the same but the idea still works the same regardless of how many links. one thing you cannot argue with is laptimes and as of right now this chassis runs circles around the stock system and half circles around exotec!! because of how the internet operates in this world,i am going to travel so some of the F1 hot spots over the next few mths to promote the chassis and some other things i am working on, this way some of you will get first hand experience on what i am trying to do and where i am headed. those of you who actually know me or have met me know how i am and the knowledge that i hold!! BTW john strahnahan is local to me we talk about these things periodically and if you have actually laid hands on one of his chassis you will see that his pod walks quite abit more than mine because of the upper links. no matter what you do you cant get away from it but you can compensate for it which is what he has figured out, just think how long it took for people to even remotely accept what he has done ( and alot still dont!)
2wdrive, what happens when the front of the pod lifts up to the point when the "slop" is eliminated? think about that for a minute and you will understand why this increase rear traction. same goes for braking which is where this chassis really shines. another thing i want to add to this whole thing is that im not really concerned with the 21.5/silvercan powered setups that much since there really is not enough power to overwhelm the chassis but there are alot of racers that are not afraid to use the available technology/power and this will benefit them more. i will admit that i dont have much experience with the silvercan but from what i have seen they arent really that fast and you dont have to use brakes, its pretty much stuck. but take that same car and put a 13.5 turbo in it and see what happens!! i like to "drive" my cars and im sure that im not the only one out here that feels this way, i think that as soon as some of the very good drivers drive one of my cars with power people will start believing that the F1's can be a force to be reckoned with, i am already a believer!!
Oh don't get me wrong...I'm not saying it won't work and don't doubt the results you have been getting. I'm just saying it isn't the IRS I had expected. Personally I love link/mono pivot designs...all the pan cars I have ran for several years now have been that type. This is another choice in the link type cars.
no worries man! the IRS is coming but i have another idea that will work probably just as good but less complex. everything i make is in preparation for something else. there is much more to come
