wgt tire trueing >
wgt tire trueing
wgt tire trueing
Old 11-13-2010, 04:29 PM
lorider75's Avatar
Default wgt tire trueing
as the title states, what are u guys using to true your wgt rear tires??
i have an ofna manual truer and the arbor i have doesnt work with the rear tires, its fine with the fronts and all 1/12th tires.
thanks
anthony
lorider75 is offline
Old 11-13-2010, 04:34 PM
thanks
anthony
Corally automatic tire truer with a CRC universal arbor. Nexus Racing has the arbor for $35.00 and it does 1/12, 1/10 and 12mm hexes (facing and removing the center seam from TC tires).
AreCee is offline
Old 11-13-2010, 05:17 PM
CRC arbor is the way to go.
mackin is offline
Old 11-13-2010, 05:51 PM
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
thanks
anthony
find one that will fit your truer,can the left hub fit the truer
20 SMOKE is offline
Old 11-13-2010, 06:24 PM
Regional Moderator
CarbonJoe's Avatar
I agree with Chuck. The CRC arbor is the way to go.
CarbonJoe is offline
Old 11-14-2010, 01:41 AM
I have the CRC arbor with my Hudy truer. Awesome piece of kit, does 1/10 touring, 1/10 pan front and rears, 1/12 pan front and rears
JR007 is offline
Old 11-14-2010, 07:17 AM
I'll stick with my Maximod-you want automatic that is easy just put it on it's side and let gravity do the work. Perfect cut every time.
BullFrog is offline
Old 11-14-2010, 09:05 PM
the 1/10 from Corally works fine as well
http://www.corallyusa.com
-=light=-
light is offline
