Old 11-15-2010, 10:09 PM   #31
jake95's Avatar
Trader Rating: 27 (100%+)
whatch these youtube video by jilles groskamp
http://www.youtube.com/watch?v=YOMu6Fu3orI
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Old 11-15-2010, 10:23 PM   #32
BrodieMan's Avatar
Been trying to find those vids for a few days now but couldn't remember what driver it was or where I had come across them. Thanks
Mark Richardson
Kawartha Radio Controlled Racers
Lakefield Hobby & Game. ExtremeRCforum
Schumacher Mi4cx CRC Gen-X 10 LE
BrodieMan is offline   Reply With Quote
Old 11-16-2010, 07:17 AM   #33
MantisWorx's Avatar
Trader Rating: 28 (97%+)
this is going to open up a big can but a few weeks ago i took a spur gear and cut rectangle windows in it (on a CNC of course!) and installed needle bearings instead of ball bearings and what i noticed is that you can actually run a fair amount of slip (if needed) and the dif rings do not get damaged as well as the heat is also a non factor! it worked very well. theoritically its all about surface area and a needle bearing has alot more of it so this means you can get away with only running three or four needle bearings and get the same surface area of a dozen ball bearings. i wish i could source out some ceramic rollers in .125 or 3mm diameter as it would be even better. one thing though is that your rings need to be perfectly flat to get the best results. i will post some pix later today
MantisWorx is offline   Reply With Quote
Old 11-16-2010, 08:26 AM   #34
Ok, here's the first worm.
I can't see how this would work very well or last very long and here's why. The outer part of the needle has a longer distance to travel than the inner part. In order to get a needle to follow the circle of the diff ring, it has to slip across it's entire length. It wants to roll straight. A ball doesn't care what direction it rolls. You would have to use tapered roller bearings to make this idea work.
woodys3b is offline   Reply With Quote
Old 11-16-2010, 08:39 AM   #35
masterhit's Avatar
Trader Rating: 15 (100%+)
http://os.3racing.hk/products.php?products_key=4773
3Racing has a diff for the Sakura that uses that concept. Always wanted to try one....... How does the old saying go? A test is worth a thousand opinions?
Mike Slaughter
masterhit is online now   Reply With Quote
Old 11-16-2010, 02:53 PM   #36
MantisWorx's Avatar
then how do they work in the first place?? a ball diff is nothing but a thrust bearing and you can by needle thrust bearings all day long , thats where i got the bearings from! this is why the bearings are placed on a radial pattern.it does work and works quite well on my d-drive cars i can slip it and it feel like a slipper clutch instead of grabbing like a ball diff does. if it didnt work there would be no such thing as a needle thrust bearing!
Old 11-16-2010, 03:20 PM   #37
Trader Rating: 42 (100%+)
I see what you are saying, but think about how a car wheel bearing works. It is the same principle.
On-point/ EA horsey power/XFactory / Hudy / Tekin / Trinity / KO Propo / Reino's Ragu
mracer is offline   Reply With Quote
Old 11-16-2010, 03:34 PM   #38
Car wheel bearings are tapered needle bearings.
Ball Diffs - how long do yours last? mjk1210 Electric Off-Road 58 11-11-2010 09:05 AM
Why no ball diffs??? Taylorm Nitro Off-Road 32 11-24-2009 12:17 AM
How to adjust ball diffs equally? Cole Trickle Electric On-Road 15 06-01-2004 05:52 PM
Ball diffs versus gear diffs Cole Trickle Electric On-Road 20 05-16-2003 04:43 PM
Ball Diffs aka LSDs.... general tips? Alvin Rookie Zone 19 10-02-2001 12:46 PM
