Novak GTB 2 Sportsman ESC
#76
Greetings- I recently purchased a Novak GTB 2 Sportsman/Ballistic 540 System 17.5T from towerhobbies. I put this system in my Losi 22. I must admit how easy it was programming this esc. Everything ran fine the first couple of runs. Though, I did notice an issue with the brakes not working well.
Now, here is where the problem started. I thought the battery was dead because, the vehicle just stopped. The weird part is the battery wasn't dead. I could pull the throttle trigger to full throttle and nothing would happen...all of a sudden it would kick into gear for a couple of seconds and then die. Again, I recharged my brand new venom 3800mah 60c battery in which was almost fully charged to began with.
I checked all wires where connected. Soldered wires where fine etc etc. I noticed when I pulled the throttle trigger the green light on the esc would stay solid green. I tried reprogramming with the same scenario. Every so often while having the throttle trigger pulled the motor would kick in...then die.
I'm no expert but, sounds to me something is shorting out? Any help would be greatly appreciated. I figured to post here before I did anything else...
Thanks Nick
Thanks Nick
#77
Thanks Nick
Thanks Nick
#79
Company Representative
The Edge has a much smaller footprint and a 10.5T motor limit.
The Edge is the perfect size and performance for USVTA competition.
#80
Can you get the Edge 2S / Ballistic Brushless Systems with a 21.5T motor for USGT racing?
#81
If there is demand, or if our items are speced into a series (like USVTA), we make the combos available. We now ship our USVTA items to our distributors.
For now, you could pair up a new Edge 2S with a RMF SS Pro 21.5 for @ $96 + $64 = $160.
If we get requests from USGT (promoters or racers) we could add the Edge2S/Ballistic 21.5T combo to our store.
#82
We are not combo-ing the Edge 2S with our 21.5 Ballistic---primarily because we try to limit combo proliferation....
#83
does any one have a pic of the gtb2 installed in a touring car. i just got a tc5 and wanted to get a gtb2 and 17.5 combo. i know the caps and the esc are kinda big so i was just trying to get some ideas on how to put it in the car.
thanks.
thanks.
#85
thanks for the pic man. just what i needed to see. I figured i would have to put my rx that way.
thanks.
thanks.
#87
For those GTB/GTB2 customers having problems with installation, you can always trade it in for an Edge 2S controller if you need to send your GTB for service. Our Edge has a much smaller footprint than the GTBs.
#88
GTB2 /Edge
Which of the two would you recommend for drifting? paired with a 13.5T motor
#89
#90
Hello,
I want to replace my servo for a Savox 1258TG
My setup is:
Ride: Jammin scrt10
Transmitter: Spectrum DX2S,
reciever: SR300
Motor: Novak ballistic 4.5 T
Esc: Novak GTB2
Can somebody tell me if i need a BEC?
And is the Savox 1258TG a good choise or is there a better one in the same price range??? ($69,99 amainhobbies)
My setup is:
Ride: Jammin scrt10
reciever: SR300
Esc: Novak GTB2
