Old 11-10-2010, 09:55 AM   #1
Default Help please
Hi !!!
I hope someone good, I can help please.
when entering curves and turn the car back and will let the car drift seems it makes
How to solve the problem?
My setup:
Sillver HPI Front, Oil 35
HPI Rear Blue, Oil 35
30X VTEC
Spur gear 105 / Pinion 27
Motor SP 4.5
Servo: Futaba S9551.
what do so that when you turn the car on a curve make the right good turn ?
Thnak you very much
regards, ciro
Ciro is offline   Reply With Quote
Old 11-10-2010, 09:59 AM   #2
sosidge's Avatar
Originally Posted by Ciro View Post
Hi !!!
My setup:
30X VTEC
Motor SP 4.5
Thnak you very much
regards, ciro
Sounds like you have too much front grip...
Many things can be tried on setup - stiffer front springs, higher front roll centre and harder front tyres all come to mind.
Having the car built well is just as important.
A quick fix is to turn down your steering rates a little. But not so much that it compromises your cars ability to navigate the track.
Old 11-10-2010, 11:45 AM   #3
Hi !!!
Thanks !!!!!
the car this assembled very well.
the car this same setup manual
not to do and help please
regards, ciro
ESC + brushless on Pine Wood Derby Car Help Please wideopen Radio and Electronics 20 03-24-2009 12:36 PM
i cant solder, help please nitro stan Electric Off-Road 80 12-31-2008 07:00 PM
KO Propo Help please acutts Electric On-Road 14 07-30-2008 04:55 PM
Futaba 2.4Ghz Problems - Help please Dennison J Nitro On-Road 18 01-18-2008 07:31 PM
HELP PLEASE CARS SPINNING 16skyline Electric On-Road 62 07-30-2007 02:32 PM
