Old 04-14-2002, 02:41 PM   #1
fatdoggy's Avatar
R/C Tech Charter Subscriber
Default Dischargers.
I recieved a ceramic(spelling?) discharger when I first got into the hobby when I bought a pair of maxx packs. My Q is, is it possible for these dischargers to send your cells into cell reversal? And also at how many amps would one ceramic discharger discharge at?
Thanks.
fatdoggy is offline   Reply With Quote
Old 04-15-2002, 07:32 PM   #2
fatdoggy's Avatar
Nobody has any idea? C'mon chuck me a bone here.
Old 04-15-2002, 10:45 PM   #3
newracer's Avatar
yes it can reverse a cell unless it also has the correct diodes to prevent it.
the amps depends on the specs of the resistor
newracer is offline   Reply With Quote
Old 04-16-2002, 09:22 AM   #4
fatdoggy's Avatar
Thanks, if I ran a doide from the pos to neg would I be able to stop it from reversing? Thanks.
Old 04-17-2002, 05:18 PM   #5
The only two ways to prevent cell reversal is to not discharge deep enough that one cell becomes completely discharged while the others still have charge in them. If this happens the ones that still have charge in them must still send their charge through the dead cell (because the cells are in series) and the dead cell receives a negative voltage from the ones that still have a charge. The voltage of the pack itself will still be positive so putting a diode here will do nothing. The second way to prevent cell reversal is to isolate each cell electrically like a discharge tray does.
As far as ceramic discharger, I guess you mean a ceramic resistor. The rate at which it discharges will depend on its resistance and the voltage in the pack, its not a constant discharge rate.
For example the resistance is 7.2 ohms and lets say you pack puts out 7.2 volts when connected to it because of ohms law V=IR we can get I=V/R so it will be discharging at 1 amp. Now as a pack discharges its voltage drops so the discharge rate will decrease.
Diodes in discharge trays don't have anything to do with cell reversal. Because in a try the cells are electrically isolated from each other the max any tray can do to a battery is bring it to zero. The diodes prevent this because they have a forward voltage drop of arround 0.7 volts. This mean for any current to flow there must be 0.7 volts or more applied. Diodes were added to discharge trays a few years back because dischargeing batteries to 0 volts can sometimes lead to a pack that likes to false peak early in its charge cycle. Now with NiMH cells they also benefit your cells because if you take a NiMH cell to zero it may never take a charge again, but it has nothing to do with cell reversal.
Hope I helped out.
Pat
patcollins is offline   Reply With Quote
Old 04-17-2002, 08:21 PM   #6
fatdoggy's Avatar
Thanks mate you helped out a heap, cheers.
Old 04-25-2002, 03:29 AM   #7
Ian
if i'm building my own tray...which diode should i use??i could think of 1N4001 and 1N5404...what the cutoff of these 2 diode..anyone got ideas??
Ian is offline   Reply With Quote
Old 04-25-2002, 04:20 AM   #8
Send a message via ICQ to JesseT
The cut-off depends on the material used only. All silicon diodes have a cut-off of 0.7 V, which will be just fine. It seams that the 1N5404 has a slightly lower internal resistance and can handle more current. Of these two it would be my choise.
http://www.fairchildsemi.com/ds/1N/1N4001.pdf
http://www.fairchildsemi.com/ds/1N/1N5404.pdf
JesseT is offline   Reply With Quote
Old 04-25-2002, 08:01 AM   #9
Ian
JesseT
thanks mate
35 amp dischargers minnesh Electric On-Road 0 09-14-2007 02:01 PM
F/s Dischargers hpiaustin R/C Items: For Sale/Trade 1 07-05-2007 12:12 PM
too many dischargers JasonC R/C Items: For Sale/Trade 5 04-17-2006 07:47 PM
Dischargers drx Rookie Zone 2 03-29-2004 03:11 AM
20 amp dischargers!!!!!!! gac1983 R/C Items: For Sale/Trade 1 03-27-2004 09:23 PM
