Old 07-13-2004, 07:34 PM   #1
Default 19 turn Vs Stock set up
Ok another set up question.....
I know Stock and Mod setups are different, but what about a car with a 19 turn?
What differences should I look at in a 19T set up for a TC3?
Thanks....
Smalls is offline   Reply With Quote
Old 07-13-2004, 07:55 PM   #2
Charlie O's Avatar
I run 19T & stock on a TC3, all i do is add a little drag brake, for the 19T & put more traction on the rear, via tires, traction compound, or ride height.
Charlie O is offline   Reply With Quote
Old 07-14-2004, 01:50 PM   #3
Default Re: 19 turn Vs Stock set up
Thanks....
What are you running now for tires, electronics etc? Is your car set up for stock w/rubber tires? What are you running on carpet or asphalt? Small or large track?
PSI Racer is offline   Reply With Quote
Old 07-14-2004, 02:01 PM   #4
J-P
J-P's Avatar
i do the same as charlie o, just a bit more drag, but i dont change anything else, if you want i can pm you my set up as it works for me on tarmac and carpet
J-P
J-P is offline   Reply With Quote
Old 07-14-2004, 06:15 PM   #5
TC3
Rubber tires
Old 07-14-2004, 06:22 PM   #6
Post
i run 19t with full roll and no breaks on asphalt with rubber tires ...dont run stock cuz "friends dont let friends run stock" .. but tires are usually 27 take offs or sorex 36s... ....
Mark Barden .
mb racer is offline   Reply With Quote
Old 07-14-2004, 06:46 PM   #7
I actually am transitioning to 19t. Our track is tiny 50x30, so we ran stock until a few weeks ago.
Old 07-14-2004, 06:55 PM   #8
Location: Built By The Racers For The Racers. Corona CA
R/C HEAT is offline   Reply With Quote
Stock 27 turn Jamesalex Electric On-Road 3 11-30-2007 12:04 PM
***FS:Stock,19 Turn,and Mod Motor's*** TexRacer R/C Items: For Sale/Trade 16 06-07-2006 06:44 AM
Whats the fastest 19 turn and 27 turn stock motor? adr3naline fix Electric On-Road 104 08-26-2005 11:03 PM
Zero Degree 19 Turn vs. STOCK... DynoMoHum Electric On-Road 4 01-09-2004 10:39 AM
What is best stock and 19 turn Mod dimples Electric On-Road 17 10-01-2003 07:22 PM
