Motor-Run In Question >
Old 07-12-2004, 07:36 PM
JDXray's Avatar
This is a stupid question, but i was motor-running in my motors, and i couldnt help but forget the AMPs and Volts were good. Say if i ran my motors at 7.0 on my Turbo GFX what are good AMps and Voltages? Is it better if the motor has higher amps and volts or lower? Sorry for the stupid question.
JDXray is offline
Old 07-12-2004, 08:41 PM
tornado
Guest
Posts: n/a
I run in my motors using the Motor Master - Surikarn Version on pulse mode 2V and 3V for 300 sec.
Bryan
Old 07-12-2004, 08:48 PM
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Bryan
Try Pulse setitng #4 too
-Dave
JDM_DOHC_SiR is offline
Old 07-12-2004, 09:19 PM
tornado
Guest
Posts: n/a
Nice to see you here Dave ! Any difference in using setting #5 other than longer pulse in #4 ? Any significant benefit ?
Bryan
Old 07-12-2004, 09:38 PM
Bryan
The time between is the pluse is a bit longer thats all
-Dave
Old 07-12-2004, 10:12 PM
The amp draw of a motor with no load on it ie>(not in a car or a dyno) means very little.....if thats what you meant....hard to understand
Joe B is offline
Old 07-13-2004, 04:16 AM
Default Re: Motor-Run In Question
it depends on what motor?if its stock theres more variables.
if you have a stock motor then normally i would go with the lowest amps and highest effciancy.
the reason for the lowest amps is because in stock motors you have bushes and these could be well centered or not.
if they are not this means amps will be high.
in general higher amps could be a shorting arm, high degree of timing,bad bearings,double mags,aligment of brushes so as you see theres a whole list of things.
obviously in mod higher degree of timing will give more power but increase in motor amp draw,like wise bad bearing will give you high amp draw but will negatively effect the motors performance.
trf racer is offline
Old 07-13-2004, 09:42 AM
Neil Rabara's Avatar
That's a bit high at 7.0. Is there a reason you are at that voltage?
Neil Rabara is offline
Old 07-13-2004, 09:44 AM
JDXray's Avatar
okay i run stock motors mostly besides one 19t epic binary. I usually motor run-in at 3.0, 5.0 and 7.0 volts(i guess its volts or amps) I like to run my motors at different settings. Is that bad?
and when there running i usally get around 4.0 avg amps (drawn i guess) and 7.0 volts avg.
JDXray is offline
