Best cooling fan? >
Best cooling fan?
Best cooling fan?
Old 02-27-2011, 01:41 AM
  #16
AGNO's Avatar
The fan # YA-0180 Yeah Racing Tornado, operates at 5 to 7.2 V.
AGNO is offline
Old 02-27-2011, 03:20 AM
  #17
Originally Posted by mac853 View Post
Really?
Never happened with me!
Lucky you.... With one single exception every YR fan we have had has failed on battery voltage in two racemeets. They are pretty good up until then but why chance it? The MM fan is better on BEC voltage so thats all I use now and it does enough.
Dragonfire is offline
Old 02-27-2011, 04:55 AM
  #18
Warren Weaver's Avatar
Trader Rating: 49 (100%+)
fantom racing high flow fan hook it to the receiver or the battery no problem 15000 rpm and ove 4 cfm air flow
Warren Weaver is offline
Old 02-27-2011, 08:12 AM
  #19
Starteur's Avatar
The Yeah Racing tornado fan puts out up to 5.5 CFM of air at 14000 rpm.
I've been using it in my 3 race cars for a year without any problems and it is pluged into my spectrum receiver.
Here's a link for a cool video!
http://www.youtube.com/watch?v=muH9TVsbNjY
Enjoy.
Starteur is offline
Old 02-27-2011, 08:19 AM
  #20
pakk's Avatar
Trader Rating: 80 (100%+)
That is pretty impressive.
pakk is offline
Old 02-27-2011, 08:43 AM
  #21
Originally Posted by Starteur View Post
The Yeah Racing tornado fan puts out 5.5 CFM of air at 14000 rpm.
Enjoy.
I love YR's typos.
So I used to run fans on my ballistic (hooked up the an LRP sphere) to lower temps for the purpose of gearing so I could have more strait away speeds. I was operating at about 160. Is this why you guys hook up fans? To gear up? Or just for better operating temps? I'm not currently running any fans because I switched to tekin and I'm getting fair straits speeds without any fans or boost in RCGT. When I got better though, if I want more speed, should I add a fan to gear up? Thanks.
TC4Racer123 is offline
Old 02-27-2011, 09:20 AM
  #22
Starteur's Avatar
It's worth testing no?
If you lower your temp by 10 degrees than you could go 1 more tooth on the pinion.
If you lower your temp by more than you could go bigger on the pinion and fly by the competition! LOL
Have a nice day
Starteur is offline
Old 02-27-2011, 11:03 AM
  #23
Enjoy.
its not 5.5 cfm and the rpms are only 7000 the cfm is 2.1 the manufacturer that makes it says so false advertisment
Old 02-27-2011, 01:26 PM
  #24
Starteur's Avatar
Buddy, I can tell you that I compared it to a Novak high speed fan that
blows 3.1 cfm of air and there is no comparison between the two, the Yeah
Racing one blows tons of air, a lot more than the Novak that is supposed to
have 3.1cfm, so that 2.1cfm I don't believe in it !
Just my 2 cents
Starteur is offline
Old 02-27-2011, 01:30 PM
  #25
Starteur's Avatar
There you go!
This is the Yeah Racing Tornado High Speed Coooling Fan:
For sale is a HIGH SPEED COOLING Fan for most 1:10th scale RC car and boat heatsinks.
# Need something more powerful than your existing motor / ESC fan? This is exactly the fan for you. Yeah Racing Tornado Cooling Fan has Ultra High Speed. You need the unmatched performance that this fan delivers. This dual ball bearing fan flows up to 100% more air than other similar sized fan.
Feature:
# For: ESC / Heatsink / Motor
# Color: Black
Specification:
# Dimensions: 30 x 30 x 10mm
# Bearing: Dual Ball Bearing
# Operating: Voltage 5V
# Start-up Voltage: 3V
# Power: 1.40W
# Fan Speed: 14000 R.P.M (20%) at 25J, after 3 min. rotating.
# Max Air Flow: 5.501CFM.
# Current: 0.28A
# Weight: 9.0g
# Connector: JST
Include:
# Tornado Cooling Fan (1 Pc)
# Round Head Fitting Screw (4 Pc)
# Instruction Manual (1 Pc)
For the best performance, please run the Yeah Racing Tornado Cooling Fan for 2 - 3 hours continuously on the first time usage-ie run the fan in first..
Starteur is offline
Old 02-27-2011, 07:14 PM
  #26
I)arkness's Avatar
http://www.speedtechrc.com/store/ebp...id=923&id=9847
I)arkness is offline
Old 02-27-2011, 10:47 PM
  #27
pakk's Avatar
I believe per Roar rules, 1 fan for the motor and 1 for the ESC. So that won't work.
But if we're going to throw Roar rules out the window, then the LRP 40mm fan wins.
I really dislike the 30mm fan rule.
pakk is offline
Old 02-27-2011, 10:49 PM
  #28
I)arkness's Avatar
here you go then
1 fan
http://www.speedtechrc.com/store/ebp...id=689&id=9848
Old 02-27-2011, 10:51 PM
  #29
pakk's Avatar
Any specs on that fan?
pakk is offline
Old 02-27-2011, 11:25 PM
  #30
Originally Posted by Dragonfire View Post
YR fans are ok on BeC voltage but fail real quick when you hook em up to your battery voltage.
pfft, not if its a 7v fan.....
Mine havnt failed connected to batt volt.
these YR (below) are really good, come with high speed Tornado fan
http://www.rctech.net/forum/attachme...g-fan-yeah.jpg
IT works great, I modded it to hold 2 fans.
1101 is offline
