servo for TC3
Old 07-11-2004, 09:28 PM
hogdaddy77's Avatar
Default servo for TC3
what is a good servo for my TC3?
hogdaddy77 is offline
Old 07-11-2004, 09:43 PM
onnetz's Avatar
what you want is a servo with high speed and torque along with metal gears....
the brand is up to you..
onnetz is offline
Old 07-11-2004, 09:50 PM
Default Re: servo for TC3
Airtronics 94452 is a good electric sedan servo.
James Nguyen is offline
Old 07-11-2004, 11:09 PM
I use the KO2123FET servo. Super fast and powerful and KO quality.
If you need the space, the you could go for a low-profile servo, like the HS-77BB
micros_rock is offline
Old 07-12-2004, 05:32 AM
For a TC3 I would say anywhere between .06 to .010 for it's speed......and "at least" 80 lbs torque........metal gears for durability....digital...if thats your preference....half the pros still chose not to run digital.......I perfer airtronics....like the 94758
Joe B is offline
Old 07-12-2004, 08:29 AM
GundamWZero's Avatar
I used a JR racing high torque servo when I ran the TC3. a high torque servo came highly recommended.
GundamWZero is offline
Old 07-12-2004, 01:53 PM
Ko propo 2123 all the time , I've had mine fo about a year and a half and it's amazing
Chazz is offline
Old 07-12-2004, 03:30 PM
SammyXp's Avatar
I'm using a Hitec HS-605BB servo I got brand new, in box for $25. 94oz and 0.13 sec @ 6.0V. It has worked flawlessly so far.
SammyXp is offline
Old 07-12-2004, 07:51 PM
I strictly run jr 8450's.
but at 120 each they get costly.... I have played with the idea of a 9451.... Anyone using one of those for steering currently? Can you give me a thumbs up or down on the 9451?
Smalls is offline
Old 07-13-2004, 06:11 AM
silver_spo0n's Avatar
Default F9402
what can you say bout the Futaba 9402 for the TC3?
i just bought one for my car, it feels and performs the same with my old s3003 at my local track's layout, F9402 is just as weak as the s3003 or
is it the set-up of my car?
an experienced racer at my local track set my car's suspension(based from his winning xray, most racers here switched to xray), can i still tweak my tc3? i'm losing patience, i'm trying my best not switching to my other car(T1R), I still think TC3s rule.
silver_spo0n is offline
Old 07-13-2004, 09:03 AM
Wency_TA03R-PRO's Avatar
You definitely don't see much of its difference in a while co'z its on the response from the receiver that transmits the signal on which to go??.. digital still the best fro TC3... I used futaba 9451 so far its great!!!..
Wency_TA03R-PRO is offline
Old 07-13-2004, 09:46 AM
Neil Rabara's Avatar
I use an Air 357.
Neil Rabara is offline
Old 07-13-2004, 06:53 PM
hogdaddy77's Avatar
Thanks for all of the input..now to find one for cheap
