variable timing - sensorless? >
Old 10-31-2010, 06:45 PM
Low_E's Avatar
Default variable timing - sensorless?
Are there ESC's that can apply variable timing on a sensorless motor?
I know a Tekin ESC can apply it when running sensored or in dualmode ... but when without sensor?
Low_E is offline
Old 10-31-2010, 09:11 PM
You can't have variable timing in dual mode, only fixed timing. Once the car is rolling, it's sensorless.
Variable timing works from feedback provided by the sensors, I don't think back-EMF from a sensorless motor provides that info.
I may get corrected....
JR007 is offline
Old 11-01-2010, 01:03 PM
it can no esc on market make it
very hard to control on decelerating
work only at 100% pwm (power)
dgaumond is offline
Old 11-01-2010, 01:33 PM
Krio's Avatar
Trader Rating: 159 (99%+)
The latest version of hotwire on the tekin not only applies to dual mode but strictly sensorless as well. So, yes there are esc's that can apply variable sensorless timing; the rx8, rs, and rs pro.
Krio is offline
Old 11-01-2010, 01:41 PM
reenmachine's Avatar
Trader Rating: 26 (100%+)
JR007 -- not only is it possible, but you own an ESC that does it!
See Krio's response above.
reenmachine is offline
Old 11-01-2010, 02:47 PM
Team Tekin
Randy_Pike's Avatar
Krio is right.
We do have variable timing in both the RS line and the Rx8. Dual mode is simply a sensored start with sensorless operation. We can still manipulate the timing without sensors.
Randy_Pike is offline
Old 11-01-2010, 03:24 PM
Well, blow me down. Another reason i'm glad i've been Tekin from the beginning! That'd be reason 212. And counting....
JR007 is offline
Old 11-01-2010, 05:37 PM
Low_E's Avatar
well I actually thought so too that the Tekin Rs Pro could do, but some friends tried to convice me otherwise, said it could not be done.
thx for the info
Low_E is offline
