over heating!!!
Old 07-09-2004, 06:17 PM
  #16
GundamWZero's Avatar
Okay, HPI never made a rally car that had an open drivetrain (a.k.a gearbox) due to the rocks jamming in to the gears. So did you buy the car as is or did you modify the car for off road use? I'll go grab my Pro 2 to see if I can help you out.
GundamWZero is offline
Old 07-09-2004, 06:20 PM
  #17
rc_square24's Avatar
it is a dual belt drive car...it has a under and over interior cover that seals the whole chassis inside.
are u sure its not the drivtrain binding?
rc_square24 is offline
Old 07-09-2004, 06:21 PM
  #18
do u have a pic of it??
HEWITT is offline
Old 07-09-2004, 06:23 PM
  #19
Okay, another question for you..... do you have ball differentials of planetary gears? the reason I am asking cause there should be also a slipper plate for that type of car. When HPI made the Rally they had planetary gear differentials to put power to the wheels and a slipper plate to handle off road conditions.
Old 07-09-2004, 06:25 PM
  #20
i might have one from when i bought it i got it off ebay and it does have a cover that has a bottom and top cover. i have had proplems with rocks getting in the belt but its not a big proplem for me really just have to stop and take them out. but it would be differnet if i was racing out doors i run carpet indors.
drifting is offline
Old 07-09-2004, 06:26 PM
  #21
what does the slipper plate look like im a noobie to onroad.
drifting is offline
Old 07-09-2004, 06:32 PM
  #22
its part or the spur gear(the large plastic gear) its like two round plates sandwiching the gear to let it slip abit under hard acceleration.
but i dont tihnk the rs4 rally comes with a slipper standard...unless if he bought one if it even exists.
Old 07-09-2004, 06:33 PM
  #23
Yeah I know......so what we do is remove the slipper for a more direct drive system so we can come off the line with some punch. However the Rally's drivetrain isn't really designed for on-road applications, although its been said that you can. So what you did was lower the car, removed or tightened the slipper all the way so that it didn't slip during the inital punch, then ran the car. I would have done it if I was running a rally onroad, so call me a noob. Are you running a two belt system?
Old 07-09-2004, 06:37 PM
  #24
everything what u said was tru what i did to run the car onroad. and no it doesnt have a slipper clutch like my xxx-t has.
drifting is offline
Old 07-09-2004, 06:43 PM
  #25
Okay, you have the makings of a Pro 2! I had to make your pic smaller to see how I can help you convert....first, get rid of the stick pack configuration and go saddle pack; it'll lower your center of gravity!
more to follow..........
  #26
it is a two belt car.
Drifting: is the drivetrain free when the motor is not in the car?
is this your only car or u have another one..if so try putting the same motor in the other car and see if it still happens.
and maybe a good pic so we can help u out
a slipper looks like this(labeled 13)
Old 07-09-2004, 06:45 PM
  #27
he still got it on. He tightned it all the way down so it won't slip.
Old 07-09-2004, 06:48 PM
  #28
ok...does it happen when its on or offroad driving?
  #29
I have a HPI option that eliminates the slipper. However I still have the planetary gears designed for off road.....
Are you running a 48 pitch gear?
Old 07-09-2004, 06:49 PM
  #30
He is running on road.......
