Old 10-26-2010, 09:52 AM   #1
Default How to get tire temperature?
How is the ideal setup for max tire temperature.
Soft inserts?
Soft springs?
anti squat at the back?
rollbar?
weight F/L? i believed a heavy front would make it understeer.
The car is a T1 fk05. it got soft springs now, a bit too hard damping i think, it also got a lot of anti squat at the back lots of toe inn and a fairly loose rear diff.
running a spool front. optionally i can have oneway spool or pure oneway
Im running some LRP carpet wheels with hard inserts now.
running on carpet.
feels ok at corner exit but too nervous at entry or shance or direction.
I want it to lean towards understeer so i can attack more.
now i have to be as gentle as i can be.
MatsNorway is offline   Reply With Quote
Old 10-26-2010, 09:55 AM   #2
sosidge's Avatar
A stiffer car is going to put more load in the tyres, as will a heavier one, and one with less damping, or one that is driven aggressively etc etc
It's not going to make much difference though. The tyres themselves and the track is the biggest factor.
If you can change tyres, change them. If not, focus on getting a good balance from your setup, rather than a setup that maximises tyre loads.
Old 10-26-2010, 10:02 AM   #3
I tried brick hard springs in the front and yes that gave hella lot of front grip. Tried the same in the back but did not get the same effect.
I had not been running it for a few months so im a bit rusty so i might have to retry a few things.
And yes i will try to get back to some sorex wheels. I had that first and they were great. Only problem was that they picked up a bit of dirt and got slippy when i did not run it hard engough or ditched that tire additive.
Old 10-26-2010, 10:48 AM   #4
Buckaroo's Avatar
You need the XXX Main chassis book and the Hudy set up manual. That answers these, and ANY other chassis/handling questions you will ever have.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 10-26-2010, 11:08 AM   #5
Foxxrocket's Avatar
You don't want max tire temperature. You want the tires at optimum temperature. Like Sosidge said, the track is the biggest factor.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 10-26-2010, 01:14 PM   #6
I do want to know what creates the maximum temp. if i Know how to do it, it makes it easier to avoid when i should have such a rare problem.
the hudy guide does not say much about temp as i can recall.
Old 10-26-2010, 01:47 PM   #7
Generally the less energy absorbed by chassis flex, springs and inserts the more energy/heat goes into the tyre.
I use stiffer spring quite a bit to get more heat into tyres.
YZFAndy is offline   Reply With Quote
Old 10-26-2010, 03:01 PM   #8
Foxxrocket's Avatar
If you race on asphalt you're going to base your tire selection on surface temperature, and maybe even air temperature. The track surface is likely to be 10-30 dagrees hotter or cooler than what you normaly feel. You want the softes tires available, without them overheating. Knowing what compound to use at what temperatures is the key.
Old 10-26-2010, 04:24 PM   #9
Your question is unanswerable because there are so many viariables, that is why you are getting so many answers. The rubber in the tires heat up due to friction, which is caused by the tire slipping over the surface they are on, and also stretching and compressing by the weight of the car and transfer of weight.
So, all of the things you noted affect tire temps. And as said before, the track surface and temperature, as well as your set-up and driving style, all affect how much grip you have.
If you are asking how to stop tires cooking, that is the golden question we all want to know the answer to! Everyone is trying to find the point of maximum force on the tires (grip) without losing traction.
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 10-28-2010, 12:45 AM   #10
Is there any good way to know when to change to higher temp rubber tyres during a race day??
Educated guess or should I actually measure tyre temp at the end of the race??
Ive 24,28,32's . I was staring with 24's & using 28's as is got hotter
Summer here is just starting (haha) so the ashfelt track can be cool in the morning & hot by about 1pm
Cheers
1101 is offline   Reply With Quote
Old 10-28-2010, 02:09 AM   #11
sosidge's Avatar
Cheers
If the tyres start squealing, they're too hot. That's a pretty good indication!
You'll also feel a change in the grip levels mid-race, if it starts to drop off, the tyres may well be getting too hot.
Old 10-28-2010, 03:08 AM   #12
Over summer you definitely want harder rubber for our outdoor tracks. Down here in Chch I used Sorex 28's in the morning, but by lunch I was on 32's. Some of the guys were using 36's and it's still only spring!
I have 28's and 32's for the most part running in the 13.5 class. A little less critical for stock (silver can).
If you are cooking them, you will often see a "wavey" pattern around the outside edge. Also, the softer they are, the faster they wear. I went through a set of 28's in 4 qualifying runs. They are practice tires now.
Old 10-28-2010, 09:41 AM   #13
Funnily enough the set of tyres that served me the best was the sorex 40r's at the South Islands. 15 laps 19s in the final is not an easy task.
Mike
ixlr8nz is offline   Reply With Quote
Old 10-28-2010, 09:47 AM   #14
Thanks for the responses ppl. im thinking softer damping in the back to start with and ofc softer tires and inserts.
Jr. in case you have not noticed im from Norway. its snow time here and most of the time the indoor tracks i have been to feels like they only got some 15 Celsius max. i usually keep my beanie and sometimes my jacket on.
Old 10-29-2010, 12:05 AM   #15
I thought you SI guys drove mainly in snow/ice conditions :-)
After all but 1 Ak outdoor meet in the last 4 months being cancelled due to rain, my rubber race tyres seem to last pretty damn well
the old 24's are pretty worn,front 2 trashed, so I guess they new 24's are 1st morning race only.
Cheers
PS
Any thoughts on RIMS??
I just use Speedmind, they are flexy so never break, and the CA glue doesnt melt them. I need every advantage when it comes to gluing.
Im thinking perhaps the lightest RIM for stock racing, less rotating mass. Or as I just kidding myself ???
Any real performance disadvantage to use flexy rather than stiff rims??
how to remove rubber tires already glued on rims? Molala3 Electric On-Road 34 05-11-2016 10:33 AM
How to cool down electric touring car rubber tires on carpet? maxg123456 Electric On-Road 34 08-16-2010 04:08 AM
How to setup a car with no traction compound on carpet Leester Electric On-Road 57 05-02-2007 01:06 PM
Tire choice for parkinglot racing????? Fiream Nitro On-Road 207 04-25-2005 07:19 PM
