Old 07-09-2004, 12:02 AM   #16
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
Originally posted by Matt Howard
Yeah, I'm having problems on this end
hey matt, send me the picture to [email protected] Ill put it up for ya
=MisFitz= NuKe is offline   Reply With Quote
Old 07-09-2004, 05:30 AM   #17
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
http://www.rctech.net/forum/attachme...&postid=589457
http://www.rctech.net/forum/attachme...&postid=589458
http://www.rctech.net/forum/attachme...&postid=589460
http://www.rctech.net/forum/attachme...&postid=589455
John Fontaine is his name...
Nice mod....Very clean....
I had bought a couple chargers to do the same thing.
Mulitple chargers in the same box.
I have one of the cheaper 3 in 1 Integy chargers to do stick packs and for my AA flight packs. Works great.
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 07-09-2004, 06:28 AM   #18
TimPotter's Avatar
Send a message via AIM to TimPotter
I would like to put a 5v USB port in my charger. Then I can run all those little laptop gadgets, like a Fan, a high intensisty Led on a bendable neck ETC, anyone have any idea on accomplishing that ?
I understand there is a 5v feed in there somewhere.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 07-09-2004, 08:53 AM   #19
etzkev's Avatar
Send a message via AIM to etzkev
Yep, thats the one I am talking about. Looks pretty good. He aded an extra computer neon in there like you are planning on doing Misfitz!
-Kevin
etzkev is offline   Reply With Quote
Old 07-09-2004, 09:26 AM   #20
Send a message via AIM to rcguy2477
johns gfx looks even better in person. I am not sure if he fixed it, but when he turned on the blue light inside the box, the screen became unreadable.
1989 Mazda Rx7
greddy t04b, megasquirt ecu, PlX wideband, 12x28x3 fmic, 50mm hks clone wg, ssqv bov, Safc, ss oil lines, walbro fuel pump, tubo intake manifolds, ssac exhaust manifold, 3" dp, 550cc primary/720cc secondary injectors, etc.
rcguy2477 is offline   Reply With Quote
Old 07-09-2004, 09:41 AM   #21
John Fontaine's Avatar
Send a message via AIM to John Fontaine
Thanks guys for the compliments. It came out well.
I'm in the process of doing a few more things to it...ie wiring coming out the front like =MisFitz= NuKe did.
Yes, the screen numbers does turn blue when the 4" neon is on inside, and i'm working on a way to protect the LCD screen from getting flooded with light but haven't found a 100% way of doing this yet. Tried black eletrical tape and metalized ductape but still does it. Need to examine it more. But thanks!
John
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 07-09-2004, 11:21 PM   #22
john, how did you mount the window to the case, and did you cut all of that yourself?
about the light, if you are running the neon wire around the window, on the inside of the case, take some black thin plastic (I can find some at out local plastic supply houses) and heat and bend it to fit around the neon, on the front side of the case...worth a try.
Old 07-10-2004, 12:20 AM   #23
FW-05RR's Avatar
FW-05RR is offline   Reply With Quote
Old 07-10-2004, 06:46 AM   #24
Guys,
here are Matt Howard's GFX pics.
Old 07-10-2004, 12:12 PM   #25
Matt Howard's Avatar
thanks for posting them, I've added green cold cathode lighting underneath it as well. I just cut some slots in the bottom of the case and mounted the lights inside right above the cutouts. It looks sweet at night races.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 07-10-2004, 06:28 PM   #26
DOMOisCOOL's Avatar
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Great job guys!
A few questions. How do you connect the fan to the main power source? Does it use the same "computer style" (molex) plug?
DOMOisCOOL is offline   Reply With Quote
Old 07-11-2004, 04:59 PM   #27
Originally posted by DOMOisCOOL
Great job guys!
Cut and splice, than solder
=MisFitz= NuKe - How I did my window was cut out a piece of lexan approximately 1/2" around the size of the window milled out of the case. Than I milled around the edge as thick as the case and then it pressed in flush. After that was done, I just shoe goo'ed it in place and it hasn't moved since. I can put things on top of the window, ie cars and such .
John
Old 09-08-2004, 11:41 PM   #28
Runin Ronin's Avatar
I saw this thread months ago and motivated me to create this:
I did all the work myself, just wanted to share Cold Cathode lighting will soon follow.
Runin Ronin is offline   Reply With Quote
Old 09-09-2004, 05:47 AM   #29
Looks sweet. Does the plexiglass sheet behind the fan have any cutouts in it? I can't tell in that picture, but it needs to draw air into the charger and out the sides.
Good job.
Old 09-09-2004, 06:06 AM   #30
Tres's Avatar
Looks good!
Tre's
www.tnt-fx.com
brushed mods vs brushless mods b-man777 Electric Off-Road 12 03-21-2008 05:42 PM
Mods and regional Mods names turn to Green? Mr. Shookie R/C Tech Site Forum 2 07-08-2007 09:50 AM
A.I. Mods? waipahe Chat Lounge 1 02-13-2007 01:04 AM
Anyone got X mods LosiRacing2004 Electric On-Road 5 03-28-2004 09:25 AM
Mods?? Chaos Electric Off-Road 1 09-01-2003 05:35 PM
