Old 10-25-2010, 03:24 PM   #1
Trader Rating: 106 (100%+)
Send a message via MSN to Texas Postman Send a message via Yahoo to Texas Postman
Default Foam vs Rubber
Somebody give me some advice, here. I've raced carpet/foams, and I've raced asphalt/rubber....Touring cars. The shock mounting positions..sway bars, and shock oil are vastly different between the 2. Now, I plan to race carpet with rubber tires. Is there much difference, between the foam set-up, and rubber?? I used to run a TC3, with 60ft/40rr..shocks mounted in the outer holes, on the towers, and 25ft/30rr in spring rates. Would these be comperable???
The TPM....
Texas Postman is offline   Reply With Quote
Old 10-25-2010, 07:51 PM   #2
Not too sure as I dont race this way, but foams give you instant grip, while rubbers you have to warm up a little before they start working more or less. Downside to foams is that they wear down and change handling characteristics unlike rubber.
Car-less (Velox V10 or 733) // RB T10.5"+" (JB Modified) // Bluebird BMS-990DMG (St) & BMS-631 (T/B) // ATS 16% // Capricorn Wheels // Protoform
"70% of the time, it works ALL the time"
DJ_Shakespear is offline   Reply With Quote
Old 10-25-2010, 08:00 PM   #3
Foams have alot of grip on carpet, so a stiff chassie and stiff springs. Rubber tire on carpet no grip soft chassie and springs to get the car to roll onto the tire with grip.
Tim
TS racing
got2bqik is offline   Reply With Quote
Old 10-25-2010, 08:46 PM   #4
rc_square24's Avatar
Why has foam touring died off in most places?
That said its nice not to worry about tire diameter, truing and change in rollout.
Do people use tire warmers for carpet rubber?
rc_square24 is offline   Reply With Quote
Old 10-25-2010, 08:56 PM   #5
Default Ah...ok
I understand what you've said...but, i still would like a more definitive answer. Is it better, I keep the asphalt settings...the spring set-up...and only change the shock oil, or what?
TPMan
Old 10-25-2010, 09:06 PM   #6
Regional Moderator
CarbonJoe's Avatar
When I converted my foam Xray T2 '007 to a VTA car, I removed the top deck standoff stiffeners, went to lighter shock oils, softer shock springs, leaned the shocks in more, 1 degree less camber up front, 2 degrees toe in in the rear, rear quick roll center from in and high to in and low. Didn't change the caster at all.
Don't know if this will help you with the TC3, but gives you the magnitude of changes moving from a foam car to a rubber car. Make the car soft all around or you'll get traction rolling if you use the foam settings.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 10-25-2010, 09:56 PM   #7
skypilot's Avatar
Trader Rating: 14 (100%+)
TPMan
yes, run your rubber tire asphalt setup on the carpet, it will be the closer of the two setups you listed, adjust from there.
semi retired..
skypilot is offline   Reply With Quote
Old 10-26-2010, 08:19 PM   #8
revo523's Avatar
I went from foam to rubber on my 009 and yes totally different setup.. Go with the setup that the car comes with and make changes from there... I do have a friend with a xray t2 and he runs vta on asphalt and carpet with the same setup. Dont know how but he does
Xray T2 009 EU Tekin RS PRO Novak 13.5 SMC 5200
Team Magic G4JS O.S.12 skyline 12plus
Spektrum DX3S
What came first the chicken or the egg?
revo523 is offline   Reply With Quote
Old 10-26-2010, 08:22 PM   #9
revo523's Avatar
Foam is way more expensive then rubber JMO...
Spektrum DX3S
Old 10-27-2010, 01:33 AM   #10
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
I missed foam when i found out it had been cut from the local tracks. It was nice to have such awesome traction and being able to put power down anywhere.
I have a couple weekends of rubber racing, and after the car is setup properly I could get used to not having foam. Just money saved on tires and not having to bring or ask people for a tire truer is already a lot of saved effort. I'm thinking about converting an old car to foam and just running it for kicks though
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 10-28-2010, 08:04 AM   #11
Conrad's Avatar
+1
It's a good reason why rubber/carpet is more popular now (UK) because the car setups are alot more similar, foams takes everything in to a different but better world
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
Old 10-28-2010, 10:16 AM   #12
AdrianM's Avatar
Yup, start with a good asphalt setup. Your best bet is to got to rc10.com and look up Barry Bakers Reedy Race setup from around 2001. Turn your front diff into a slipper spool (take out the diff balls, clean your diff bevel gear and rings and reassemble with no balls or diff lube). This will let an outdrive slip if you whack something. If you run a solid spool you will bend a drive shaft if you touch anything.
Adrian Martinez
Foam vs Rubber Tires Toma2525 Electric On-Road 109 05-02-2005 05:44 PM
Foam vs Rubber.... MartynD Electric On-Road 38 01-14-2005 12:16 AM
Foam Vs Rubber fastolfart Australian Racing 66 07-09-2003 04:04 PM
Foam vs. Rubber for big races Brian McGreevy Electric On-Road 47 02-03-2003 10:20 PM
Tires Foam vs. Rubber you decide! FoamDonuts Electric On-Road 81 03-10-2002 07:59 PM
