17.5T Motor - Which is better?
OK, the question I have is which 17.5T motor is better out of the following:
1-Novak SS Pro
2-Team Epic Duo 2
3-Team Epic Duo 3
4-Novak 3617 Ballistic Spec
It will be powered by a Hobby Wing Xtreme Stock Brushless ESC, so what would be a better choice? Thanks guys (and girls if you lurk round here )
1-Novak SS Pro
2-Team Epic Duo 2
3-Team Epic Duo 3
the absolute hands down best motor is the one that I chose to use at that moment, same for esc, chassis, tires, body, servo, and everything else I have.
there is NO best anything. its all in what you "think" is best and what works for you.
Hahaha I like your thinking, so far I like the Epic Duo 3, and 1-3 are all the same price, #4 being a little more expensive, but not by much.
I like the Duo Series I have a Duo1 13.5 Duo 2 17.5 And i have a duo3 on the way.
Today, I removed a 13.5 Duo 2 from my 1/12th car and substituted it for a 13.5 Novak Ballistic. Got an immediate 1.5 seconds reduction in lap times.
Are you comparing apples to apples? The Novak motors come from the factory set to 30 degrees timing on the motor. Aren't the Duo2 motors around 24 degrees timing when the endbell is set to the indicated 0 degree mark? Would a gearing or motor timing change have resulted in the same lap times? If your lap times changed that much, you probably weren't setup correctly for that motor's "sweet spot".
Company Representative
After you have run a motor (any mfgs' motor) for a while, you may have weakened your rotor magnet. Using dynamic timing escs can demagnetize your motor because of overheating. Installing a brand new motor (new rotor) should should make your car run better; but, replacing the rotor in your existing motor will probably make your "old" motor run better, too...
BL motors should be maintained and bearings checked regularly:
Video: How to Clean Your BL Motor
Well then, the Epic D3 takes the cake!! Thanks guys!
