What chassis?
Old 10-24-2010, 02:45 PM
Moderator
*Super*'s Avatar
Default What chassis?
I'm looking to build a Vintage Trans-Am car, what would be the best chassis to use for that? I was thinking of using my Sprint 2 but I hate the belt drive.
*Super* is offline
Old 10-24-2010, 03:18 PM
locked's Avatar
Belt drive can be great. The problem with the Sprint2's belt drive is the lack of cutouts below the diff pulleys, so it traps things and chews up belts and diff casings. If you dremel that area of the bottom chassis out it can spit out debris before it chews everything up and also make sure you have the front belt tensioned enough to not rub through your battery and get the motor placement just right so the belts don't hit the motor, then that particular aspect of the sprint 2's design will not bother you as much
People use sprint 2s in the slower classes all the time. They can be set up to drive well enough with a bit of work.
locked is offline
Old 10-24-2010, 03:47 PM
Foxxrocket's Avatar
Shaft drive isn't any better.
Foxxrocket is offline
Old 10-24-2010, 10:04 PM
Moderator
*Super*'s Avatar
Thanks for the input. I'm gonna try that.
*Super* is offline
Old 10-24-2010, 10:16 PM
Moderator
*Super*'s Avatar
Why do you say that? What problems do you have with shaft drives?
*Super* is offline
Old 10-24-2010, 10:43 PM
Guest
man i just took 1 an 2 place tonight with my hpi sprint 2 sport. i have 2 cars, i drove one with all the graphite parts. my friend drove a bone stock car that was took out of the box last night. the cars drove great!!! and the stock speed control and motor was great!!!!! the car got better with each race!!! please check them out! dont hate on them man.
LOSIRACER77 is offline
