Old 10-10-2001, 05:26 PM   #46
spider's Avatar
Send a message via Yahoo to spider
does anyone here know if the new aluminum bulkheads and damper stays of the evo2 will be available separately? in other words, can the new parts be attached the the old tb evo?
spider is offline   Reply With Quote
Old 10-11-2001, 03:59 PM   #47
TFR
TFR's Avatar
here is a better picture of the TB EVO II...
http://www.tamiya.com/japan/show0110/broadcast2.htm
TFR is offline   Reply With Quote
Old 10-11-2001, 04:00 PM   #48
TFR
TFR's Avatar
not sure if the Alum Bulkhead is interchangable with \the first TB Evo....
Old 10-11-2001, 08:53 PM   #49
spider's Avatar
thanks for the link.
looking at the gear cases, it appears like it is possible to use the new aluminum bulkheads for the old tb evo provided that the new shock towers will be used as well.
interesting. is the new lower carbon fiber deck.
Old 10-11-2001, 09:32 PM   #50
TFR
TFR's Avatar
The lower deck has to be Carbon Fiber...
got all those holes now for the batteries...less weight too...
oh ya, one more thing, is the first TB Evo a balance car?
since all the electronic is on one side and the battery is on the other side?
Old 10-11-2001, 11:36 PM   #51
spider's Avatar
from the stock setup, yes.
once i put in the batts and electronics. there is no noticable leaning on either the battery or electronics side. here's what i normally use:
futaba s3003 servo
futaba fm receiver
novak super rooster (soon to be replaced with a tc2)
tamiya type t or type r motors
team orion active sport pack ni-mh 3000mAh
with turning practices i do not notice any bias on either left or right.
hmmmm.... come to think of it, maybe i should weigh the electronics and batts....
Old 10-11-2001, 11:39 PM   #52
spider's Avatar
i forgot to mention that the hole on the lower deck for the motor is different.
i was hoping that they'd come out with a chassis that has battery holes on both sides. maybe i should get a new lower deck and test if i can make additional batt holes on the motor side.
Old 10-13-2001, 09:46 AM   #53
Topforce's Avatar
Default Re: Kraig...
Originally posted by Atlas
I Heard The Yokomo Threaded Shock Collar Will Work On The Tamiya Shocks, You Might Want To Give Them A Try--Only Problem Is The Blue Collars Might Not Match up To The Silver Shocks...
Thats is true, i use them on my trf414m and it works much easier the the orginal one's.
Topforce is offline   Reply With Quote
Old 10-14-2001, 06:54 PM   #54
spider's Avatar
has anyone tried making additional battery slots on the other side of the carbon fiver lower deck?
my idea is to cut an additional three batt slots on the other side of the lower deck so that i can have more control over the balance of the car.
what do you guys think?
Old 10-15-2001, 02:13 AM   #55
spider's Avatar
Default tb evo 2
aluminum arms too?!?! man! this i have to see personally. i couldn't get a good look at it from the pics over at the tamiya site.
Old 10-16-2001, 12:35 AM   #56
Dragon's Avatar
Send a message via ICQ to Dragon
it does look more fragile than the evo1.....
like the ta04pro....is it true that stick thinggy that connect the top part of the wheel with 2 ball like thinggys break easily
....(i forgot what they call it...poor memory...)
Dragon is offline   Reply With Quote
Old 10-16-2001, 01:25 AM   #57
Alvin's Avatar
I guess u are refering to the Camber Link. No, on my 04 that does not break easily, at most it pops off at very bad crashes (My best guess. Never had a crash which popped the front camber link ), but u can pop it back in again. WHen I wrecked my front A-arm on my 04 the worst happened to the camber link was the plastic bent out of shape. The metal rod was intact.
Alvin is offline   Reply With Quote
Old 10-16-2001, 10:03 PM   #58
razzo's Avatar
Send a message via Yahoo to razzo
If anyone is looking for TB Evo cheap, check out the 'for sale thread' under basement clearance sale.
It's REALLY CHEAP!!! you can strip it down and use it for parts car!
razzo is offline   Reply With Quote
Old 10-17-2001, 08:47 PM   #59
spider's Avatar
Default small talk
for the past two weeks i suffered 2 major glitches resulting in the
tb evo1 doing a head on kiss with a wall at full throttle on both
occasions. it flew up about 2 feet and landed on its back with a wham still going at full throttle. ouch.
maybe its in my receiver or likely the way i re-layed out my antenna. this did not happed before i re-laye dout my antenna wire. i'll return the layout of the antenna wire tonight and will test again.
the damage? it popped a 3x15 tapping screw off the front bumper, made a 5mm hole in front of the body of the car, the steering was tweaked a little but nothing bent or broken and easily adjustable. and the car still ran.
i think its a good buy. 8)
Old 10-20-2001, 02:12 AM   #60
newracer's Avatar
R/C Tech Charter Subscriber
what setup are people using? specifically for prrepared asphalt tracks? I have found the best to be really soft in the front (Tamiay gold) and really stiff in the rear (new Tamiya white). anybody else the same?
newracer is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
