Old 02-01-2002, 11:18 PM   #196
imataquito's Avatar
Send a message via ICQ to imataquito Send a message via Yahoo to imataquito
yes and no ... generally no difference
but some people say there is cause thers less rotating mass
i found out that if i use a smaller gear to get the same ratio the car accelerates FASTER
imataquito is offline   Reply With Quote
Old 02-01-2002, 11:57 PM   #197
newracer's Avatar
R/C Tech Charter Subscriber
with the bigger set you can get a better gear mesh
newracer is offline   Reply With Quote
Old 02-04-2002, 12:55 AM   #198
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
I am now using a TB Evo I and cant figure out why my spur and pinion keeps getting busted. On races I notice the rest of the guys dont get small stones on the track of their 04's and 414's. It really bothers me when I hear the sound of a busted spur. I have tried different ways of meshing it properly but still happens.
Geetoo is offline   Reply With Quote
Old 02-04-2002, 01:27 AM   #199
Try to drive on the clean parts of the track. I know when I get into the dusty, dirty areas, the spur on my 04 gets messed up. If I stay on the clean parts of the track, however, my gears can last a long time. One 'excursion' into the dirty areas is all it takes.
Potato is offline   Reply With Quote
Old 02-04-2002, 08:23 AM   #200
newracer's Avatar
I went through a lot of spur gears on my EVO too, I think it is mostly due to the difficulty in getting a correct mesh. Really look close at you gear mesh.
Old 02-04-2002, 09:57 AM   #201
Geetoo's Avatar
Default Spur problem
I tried running my evolution 2 hours ago and evrything seems fine. I used a 88t spur with a 36 tooth pinion all brand new in a medium size indoor asphalt track. Maybe it was just pure bad luck on meshing or getting those tiny dirt into the spur. I ranned at least 5 batteries and everything was alright. A fiend of mine told me to put protective lexan plastic on top of the spur mounted on double sided tape. Hmmm...I will give ot a try and let you guys know if it works.
Old 02-04-2002, 10:26 AM   #202
TRF-Powered's Avatar
Humm.... for all the races that I ran I only have one spur gear worn-out. I think what happened you guys who busted their spur is really just pure bad luck.
One thing though, try not to run the car on the street where loose small rocks are everywhere. that will just incearse you chance of busting it.
I run my cars at indoor track, and outdoor paved parking lot, and so far only one spur gear worn out which is due to one-time bad gear mesh.
TRF-Powered is offline   Reply With Quote
Old 02-04-2002, 06:47 PM   #203
shockwave's Avatar
Send a message via ICQ to shockwave
heres the car. its 230 CDN. Worth it? Or shoudl I keep hunting for that Evo?
shockwave is offline   Reply With Quote
Old 02-04-2002, 11:18 PM   #204
newracer's Avatar
shockwave check out this one
TB Evo
Old 02-04-2002, 11:27 PM   #205
shockwave's Avatar
I'll wait till the auction is about ended if its still low I'll bid thanks!! btw...hows it look there were no pics there
Old 02-05-2002, 09:39 AM   #206
newracer's Avatar
I couldn't see the picts either, the seller posted to e-mail him for picts if you couldn't see them.
Old 02-05-2002, 10:53 AM   #207
Technoskid's Avatar
Default TB Ratios
Motor Gear Ratio Spur Gear Pinion Gear
540 Type Motor 6.85:1 58T (in kit) 22T (Item 50357)
Sports Tuned 6.85:1 58T (in kit) 22T (Item 50357)
Dyna Run Stock 6.85:1 58T (in kit) 22T (Item 50357)
Dyna Run Super 7.94:1 58T (in kit) 19T (in kit)
For the avid TB Evo enthusiasts. This might help you guys. Keep on racing.
Technoskid is offline   Reply With Quote
Old 02-05-2002, 05:32 PM   #208
shockwave's Avatar
thanks
Old 02-05-2002, 05:38 PM   #209
shockwave's Avatar
I can;t bid I'm 17
Old 02-07-2002, 10:52 PM   #210
Dragon's Avatar
Send a message via ICQ to Dragon
hi guys, any idea where i can get the carbon lower deck for the EVo 1?
..i spoilt mine.....and my lhs cant get it from the local distributer....
Dragon is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
