Old 01-06-2002, 07:41 PM   #151
spider's Avatar
Send a message via Yahoo to spider
newracer: the arms are the same as the first tb evolution (checked with the japanese site)
the new kit (2) came out a little cheaper than the tb evo 1 according to reports that just came in from hong kong.
spider is offline   Reply With Quote
Old 01-06-2002, 07:45 PM   #152
spider's Avatar
Originally posted by shockwave
not getting an evo now. found out if I gbrake it. I can;t get parts n e where near here! have to get them from the states. I'm getting a TBO1 instead. it has every Tamiya Factoy part you can buy on it!!
most of the parts of the evo 1 are either from the tg10/tgr or the tb01. the evo specific parts would be the arms and the decks. in the case of the evo 2 the alum bulkheads are new to the line.
Old 01-06-2002, 11:18 PM   #153
shockwave's Avatar
Send a message via ICQ to shockwave
but wut are the chances of the arms braking when you race between 2x4?? pretty good. I can;t risk it.
shockwave is offline   Reply With Quote
Old 01-07-2002, 03:09 AM   #154
Just been looking at the evo-2 and it looks very nice.
It still has the aluminium prop shaft though. I thought Tamiya came out with a carbon fiber version. What ever happened to that? Is an option part?
Thanks.
Yorkie
Yorkie is offline   Reply With Quote
Old 01-07-2002, 03:13 AM   #155
r32
r32's Avatar
Send a message via ICQ to r32
I hope it isn't the same carbon propshaft that came out when the TB-01 was first introduced.
That one delaminated into loose strands of carbon fibre after I used a 11 turn triple in my car.
I bought the aluminium propshaft for about a third of the price and have had no problems since.
r32 is offline   Reply With Quote
Old 01-07-2002, 08:29 AM   #156
newracer's Avatar
R/C Tech Charter Subscriber
actually if the TB-01 your are getting has all the hop ups, it probably has the long suspension setup which is the same arms as the Evo, the Evo is very durable, my friend and I have crashed running very hot motors (7x1 and 10x3) with no broken parts
the carbon shaft is awfull, it will delaminate with just a stock motor after about 10 runs
newracer is offline   Reply With Quote
Old 01-08-2002, 12:00 AM   #157
spider's Avatar
Thanks.
Yorkie
that one's weak. it frays at the edges when driven hard. may still be under re-development.
Old 01-08-2002, 12:34 AM   #158
spider's Avatar
that's true. i've been mishandling my tb evo like its my first on-road kit (which it is) and the only thing that broke is one of the ball connectors holding the damper. this one's connected to one of the suspension arms. so i have to get a cutting tool to make a screw driver slot to get he thing out....
Old 01-10-2002, 09:36 AM   #159
Does Lunsford make Titanium turnbuckles for the TB01 evo? I just got the evo II and the turnbuckles suck, no place to grip. no wrench. Hurts my hands.
racingdc9 is offline   Reply With Quote
Old 01-10-2002, 09:51 AM   #160
Ty
Ty's Avatar
Trader Rating: 29 (100%+)
Call up Lunsford to see, or most LHS carry a tray full of various sizes of titanium turnbuckles. If they don't have a tray you have them order any length in pairs from Lunsford. You might have to use standard plastic rod ends because the Tamiya is metric and won't thread properly.
Ty is offline   Reply With Quote
Old 01-10-2002, 09:53 AM   #161
THanks
Old 01-11-2002, 05:20 PM   #162
TRF-Powered's Avatar
Hi all,
did any of you switch the TB evo's steering into the Al. racing steering? if so, is part number 53365 te right steering set to get? I got myself that al. racing steering thing, but it doesn't seem to fit right on my evo. the Lower steering rod that connect two steering thing is too high up, it got caught on the drive shaft. how to fix this??
TRF-Powered is offline   Reply With Quote
Old 01-21-2002, 10:39 AM   #163
Default TB Evo II
Has anyone bought one yet and run it? How do you like it?
coolrcdad is offline   Reply With Quote
Old 01-21-2002, 11:14 AM   #164
I got the new EVO II and it's pretty good. I set the car up as the instructions stated and the car handled well. The red springs that came with the car, with 30 weight oil, are a tad bit soft. The car was leaning a little too much even with the sway bars. I changed to stiffer Tamiya blue springs at all 4 corners and added about 2mm of kick up to the front and the car only has a slight onpower push coming out of a turn. This is all with a stock motor. I haven't tried mod yet. The car is great off of the line and the straight line speed isn't bad either.
Old 01-24-2002, 01:49 PM   #165
Any set up tips for the EVO1 or II? Especially for mod. What gearing would you use for a 12X2 motor? 88T and what pinion?
thanks
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
