Outdoor asphalt track biulding >
Old 10-22-2010, 08:44 AM
Trader Rating: 8 (90%+)
Default Outdoor asphalt track biulding
What do most people use for barriers and markers? Where can they be purchased?
Tha Skinny is offline
Old 10-22-2010, 09:36 AM
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
pvc,2x6,plywood,dots are old disc from a farmer
20 SMOKE is offline
Old 10-22-2010, 01:01 PM
Barry_Hughes's Avatar
If it's permanent - concrete kerbs (and barriers where needed)
Fire hose filled with sand
Barry_Hughes is offline
Old 10-22-2010, 02:16 PM
Some more suggestions here:
http://www.rctech.net/forum/nitro-ro...-building.html
spongerX is offline
Old 10-22-2010, 02:33 PM
BCbud's Avatar
Trader Rating: 37 (100%+)
Good day!
Here is a link to what our club uses for a temporary track.
http://www.rctech.net/forum/rookie-z...ble-track.html
BCbud is offline
Old 10-22-2010, 03:10 PM
locked's Avatar
At our club we don't run nitro, so we don't bother with outside walls. The few walls we have are each made from two 2x4s screwed together so they form a ^ shape. The corner markers are heavy rubber mats around an inch thick that have been beveled with a power sander and then painted. It is very forgiving.
+ YouTube Video
Last edited by locked; 10-22-2010 at 04:28 PM. Reason: embedded video for easier viewing
locked is offline
Old 10-22-2010, 07:43 PM
picco007's Avatar
Trader Rating: 97 (100%+)
+ YouTube Video
Do you have a picture of the drivers stand?
picco007 is offline
Old 10-22-2010, 09:17 PM
HB Moose's Avatar
plastic rain gutter down spouts make good cushions for solid walls
HB Moose is offline
Old 10-22-2010, 09:31 PM
evostyle's Avatar
Trader Rating: 102 (98%+)
I like the idea! Where can I get the mats?
evostyle is offline
Old 10-22-2010, 09:47 PM
Trader Rating: 20 (100%+)
Default Drivers stand
The drivers stand is a movable trailer 2 tier. The fist tier was storage for the tack parts. It was hollow and held the track barriers. The second level was the stand with a removalbe stair case. I know I lifted it into place many times.
The track is a local club in Toronto Canada at a Home Depot parking lot. It was run by the Fastcats Crew.
As Locked said the barriers are made with 2x4 in a /\ formation with connector made of 1x1a . The rubber mats are made from horse flooring (JB) from a stable.
I was setting up a temporary track and the corner dots I was using were brake chamber diaphrams. If you know about air brakes from trucks or trailers I was using the tossed away piggy back (maxi) rubbers as dots. Easy for me to get because I am a Truck Trailer mechanic.
zleader_99 is offline
Old 10-22-2010, 10:16 PM
wingracer's Avatar
Trader Rating: 24 (100%+)
I do not recommend pvc. Our parking lot club started out with it and you talk about a car killer. Bumpers go under the pipe, hitting the tire and breaking everything.
2x4 works much better.
wingracer is offline
Old 10-22-2010, 10:34 PM
pakk's Avatar
Trader Rating: 80 (100%+)
+ YouTube Video
That track looks like it turns boys into men.
pakk is offline
Old 10-23-2010, 12:33 AM
locked's Avatar
This was shot one of the first days the track was set up, before we turned the drivers stand.
+ YouTube Video
Several parts met their demise from cars swinging out too wide entering the straight before the drivers stand was rotated. A few parts were mine. The outer wall did allow me to technically beat a certain top dog at the club twice one day when I finished 5th and 7th and the wall ate his car.
locked is offline
