XXX-S hop-ups!!
Old 07-14-2004, 05:33 PM
  #91
mwcet8k's Avatar
Originally posted by jkerr0043
I didn't realize what the entry list looked like until after I sent mine in for modified. Basically the modified class is what all the factory guys (except dumb ass me) signed up and 19 turn is what everyone else signed up for. I'm going to get a lesson from these guys. Take a look at this enty list.
http://www.kopropo.com/KO_GP_entries.htm
It'll be fun to see where I really stack up.
Well, at least you don't have to worry about qualifying for anything lower than the C-main!!
Man, I wish I lived closer to the Tamiya track.
mwcet8k is offline
Old 07-14-2004, 05:35 PM
  #92
TL_XXX-S_racer's Avatar
right now i race weekly at an indoor carpet track. The place is nice but the track is so easy. The owner doesnt want to change it cause he says it takes too much time to change it from oval to touring car and back again.
I also race once a month at an outdoor asphalt track. Their tracks are big and they prep the track so alot of traction and some good cometition.
All i can do for right now is practice and ask companies.
TL_XXX-S_racer is offline
Old 07-14-2004, 06:42 PM
  #93
Well put. Winning at a local and regional/national level if very important. I think though that how you're preceived off the track is just as important.
I'm okay at our club races, but the reason why our hobby shop sponsered us was because we were nice guys. We would help out other racers and I've been known to hand out spare parts if I had it. I don't consider myself sponsered as much as a shop representative. Does that make sense?
PSI Racer is offline
Old 07-15-2004, 08:16 AM
  #94
hey guys one question.
I just got some of that Paragon traction stuff for the tires. Can u put the stuff on rubber and foam tires or only one of those. I know you put the stuff on the tires but what do u do after that. Will the stuff make my car harder to handle cause it will have to much traction and not want to turn? I've never used this stuff before.
Old 07-15-2004, 08:56 AM
  #95
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
All depends on the track. Is that what they use at your local track? If you go to SoCal and don't use it you're nuts but most parking lots it'll make you look like a drift car.
Jon Kerr is offline
Old 07-15-2004, 09:27 AM
  #96
why will it make my car look like a drift car? wont it give you more traction? My local track is a parking lot. they clean it off and spray the sugar water for traction too. So wont the Paragon stuff give u more traction. My other track i race at is a carpet track. They use the Paragon stuff too.
Old 07-15-2004, 09:42 AM
  #97
Jon Kerr's Avatar
My experiance with Paragon on parkinglots is that no matter how well they blow it off and spray it, it's still dirty. Paragon will pick up all the dirt off the track and it'll stick to the tires and make you loose grip. I've used Simple Green on the tires in cold weather but not in hot weather. When you do SG, I use it after the run. Clean the tires with it and let it sit. I'll be dry by the time you're ready for another run. But I do this only if the track is cool. Below 80F. If it's too hot out, they'll get greasy and you'll endup sliding all over.
Jon Kerr is offline
Old 07-15-2004, 09:48 AM
  #98
ya but i've seen guys at the track putting that suff on the tires when the track is like 95 degrees, and their cars dont slide around. So i put the stuff on the tires about 30 minutes before my race then wipe the tires off and then go out to the track. Then wipe them off after the race. and do the same over again.
Old 07-15-2004, 11:01 AM
  #99
Jon Kerr's Avatar
Are you talking about Simplge Green or Paragon?
Jon Kerr is offline
Old 07-15-2004, 11:04 AM
  #100
Paragon.
Old 07-15-2004, 12:01 PM
  #101
Jon Kerr's Avatar
Ask ten people how to put Paragon on, you'll get ten answers. When I'm at a track that uses paragon, I put it on about five minutes before the heat, then wipe it off after about a minute.
Jon Kerr is offline
Old 07-15-2004, 01:37 PM
  #102
all i wanted to know is that if there are different kinds of Paragon for different tires. Say one for foams another for rubber tires. Is there or just odorless and one with odor. Does it help your tires last longer too? Cause ive heard someone say that it helps it wear less on foam tires after the little line of the foam goes away.
Old 07-15-2004, 02:07 PM
  #103
Jon Kerr's Avatar
I don't think there's different kinds for foam and rubber. They do have two different compounds but I don't think they're specifically for one kind of tire. I've never run foams so I don't know about the wear factor with them but on rubber tires on asphault I'd have to say if anything they wear faster.
Jon Kerr is offline
Old 07-15-2004, 03:28 PM
  #104
hey thanks for all the info you've given me.
Old 07-15-2004, 03:34 PM
  #105
Jon Kerr's Avatar
Any time. That's what I'm here for.
Jon Kerr is offline
