Old 10-18-2010, 07:32 PM   #1
phisher's Avatar
Trader Rating: 14 (100%+)
Default Best replacement shocks for touring car
I recently stripped the cap while rebuilding the shocks on my Team Magic E4. I took great care to line up the threads but, still managed to do it. I haven't been impressed with the build quality of these shocks in the first place. This got me thinking; Should I look into replacing these shocks for a different brand or should I just replace the shock cap? I have always loved the Tamiya TRF shocks and was thinking about going that route. However, maybe others would have some suggestions on replacement shocks. Thanks for your input.
www.MichiganRC.net
phisher is offline   Reply With Quote
Old 10-18-2010, 08:01 PM   #2
stiltskin's Avatar
Trader Rating: 102 (100%+)
The Tamiya shocks have been the best shocks on the market (IMO) for awhile. The TOP Photon shocks are almost identical to the Tamiya shocks.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 10-18-2010, 08:44 PM   #3
You can't go past Tamiya TRF's. I've used Losi, Associated, HPI (Hot bodies), CRC, Corally, and Tamiya, and they win hands down.
I don't have any at the moment, but if I was replacing shocks it would be my only choice
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 10-18-2010, 08:56 PM   #4
Foxxrocket's Avatar
Tamiya shocks with XRAY springs.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 10-18-2010, 10:50 PM   #5
alcyon's Avatar
the fit and finish may be nice, but i find tamiya shocks very difficult to set the pressure equally, and with the urethane bush, the inner pressure can be very high, causing my car loss of traction. thats why i am selling the shocks off.
alcyon is offline   Reply With Quote
Old 10-18-2010, 10:57 PM   #6
STLNLST's Avatar
Trader Rating: 21 (100%+)
Tamiya......hands down!!!
STLNLST is offline   Reply With Quote
Old 10-18-2010, 11:48 PM   #7
Trader Rating: 15 (100%+)
don't use the bushing.
use little to no rebound.
and if you can't get the pressure equal... the parts are all the same, the only variable is the person building the shocks.
swarb is offline   Reply With Quote
Old 10-19-2010, 12:10 AM   #8
Zac_with_no_K's Avatar
Wow.. I need some TRF's!! I also need a job..
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Zac_with_no_K is offline   Reply With Quote
Old 10-19-2010, 01:39 AM   #9
JayBee's Avatar
Trader Rating: 31 (100%+)
Just about everyone says Tamiya....my choice would be Schumacher shocks.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-19-2010, 06:55 AM   #10
I had the same issue with the E4 shocks, they are just nasty to rebuild right. I solved the problem by using the Tamiya TRF shocks and you can still use the TM springs. You will need to change out the mounting, I used the Tamiya balls to mount the shocks.
Boy, did that ever improve the cars handling.
If someone says they have problems with Tamiya shocks it usually is operator error.
AreCee is offline   Reply With Quote
Old 10-19-2010, 07:02 AM   #11
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
I ran Schumacher shocks on my TM E4 for over a year
Old 10-19-2010, 07:06 AM   #12
alecladanga's Avatar
+1
alecladanga is offline   Reply With Quote
Old 10-19-2010, 09:28 AM   #13
hi do you have the tamiya shock part number and if possible wear to buy?
Corally_27 is offline   Reply With Quote
Old 10-19-2010, 09:42 AM   #14
buffalobill989's Avatar
Trader Rating: 50 (100%+)
SENT YOU A PM
buffalobill989 is offline   Reply With Quote
Old 10-19-2010, 10:36 AM   #15
Trader Rating: 16 (100%+)
1st thing I ignore on my E4RS are the shocks from them, I don't even bother to try them. I go straight to the TAMIYA BLUE SHOCKS and is on my E4RS since day 1 and now almost 2 years. Best shocks in the market for around $60 USD.
Oh...you also need to buy their WHITE damper plate, the black one that came with the shocks are junk.
Tamiya Championship Series Neil Rabara Racing Forum 21260 Yesterday 11:25 PM
Tamiya mini cooper sipaboy Electric On-Road 29687 12-10-2017 04:07 AM
Best Shaft drive touring now ioxqq Electric On-Road 53 01-05-2010 06:28 AM
The Best Shaft? Pro-4, TC-4, or Yok SD? Opinions Requested! ApexPredator Electric On-Road 99 05-03-2005 06:20 PM
