Old 04-13-2002, 10:41 AM   #16
what do you guys think of the ko propo ex 11 presto?
was ist los? is offline   Reply With Quote
Old 04-13-2002, 01:33 PM   #17
Super Moderator
Grizzbob's Avatar
Scroll up & read my original reply, I already recommended it to the thread's starter.....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 04-13-2002, 01:38 PM   #18
GO for the M8 it will take your driving to a new level
teamAE is offline   Reply With Quote
Old 04-13-2002, 09:12 PM   #19
Super Moderator
Grizzbob's Avatar
Ok, let me elaborate, I've had(& still have) a Presto for over 5 years, & I still like them alot(though I now have an EX-1 Mars for my primary radio). It has plenty of features & is of VERY high quality. I still keep one Presto as my backup, & I still use its reciever in one of my cars(it's a KR-297F, the same as the Mars uses, I consider it one of the best made), & even better, it can be found for around $150 at mail order shops......
Bob Seay
Go Pokes!!!
Old 04-13-2002, 10:41 PM   #20
Regional Moderator
disaster999's Avatar
Originally posted by Grizzbob
I'd suggest you have a look at KO's EX-11 Presto, it has about all the features you mentioned & it can be found for around $150.....
not PCM function tho
disaster999 is offline   Reply With Quote
Old 04-13-2002, 10:46 PM   #21
Regional Moderator
i agree with what you all said...
dennis..go with the one that you think feels the most natural in your grip...you have to try it before you could make up your mind!
Old 04-14-2002, 12:51 AM   #22
Super Moderator
Grizzbob's Avatar
It's true the Presto doesn't have PCM, but you're not going to find ANY new radio that does for the price the original poster asked about(the cheapest PCM radio I've seen was around $290 or higher). I'm trying to keep his budget in mind(if money was no object, I'd recommend an EX-1 Mars, the finest radio I've ever owned or used, but he DID say at $150 or less). Also, I think that PCM radios in most of our applications are overkill, I RARELY have any glitching problems, & I've never had a PCM radio(you just have to take care in setting ALL the electronics up, & buy quality components, which KO certainly is).....
Bob Seay
Go Pokes!!!
Old 04-16-2002, 08:39 AM   #23
Cole Trickle's Avatar
Do the grip test !
Recently, I bought a new radio. I checked out Multiplex, Hitec, KO and Futaba. I ended up with KO Propo Presto EX-11.
At my opinion, these are the highligts:
Fits my hand nicely. (The Mars are actually too small for my hands).
Very very small/light RX.
Reliable.
Good functions. Probably more, than you request.
Very easy to use.
Very good manual.
Extremely good value for the money.
It fits your budget.
Cole Trickle is offline   Reply With Quote
Old 04-16-2002, 06:54 PM   #24
ijnek's Avatar
Send a message via ICQ to ijnek
Smile
gd manual from KO?...tat's new
2 mi,their manuals r always japlish(japan style english)...
full of minor mistakes which could translate in a major mistake
BUT,their products r definitely the best n even bcos of their quanlity,i am able to tolerate their jap-lish...
anyway,go choice on the KO controller,tons of features n i believe u wun even use all of them unless u r racing nitro...
ijnek is offline   Reply With Quote
Old 04-17-2002, 10:51 AM   #25
DennisNyholm's Avatar
Default THANKS!!
Thanks a lot for all the replies. I have decided on either the KO PROPO EX-11 or the FUTABA 3PDF. The KO PROPO has a few more features and is a little cheaper.....I have always liked FUTABA's equiptment though. THe KO PROPO is a little small for my hands while the Futaba feels a little better.....the only thing that i was confued about was the KO PROPO 4: channels
It comes with a 4 channel trans and a 2 channel reciever. could I just use any 3 channel FM reciever to get 3 channel use? I have a nitro boat that uses three channels and was thinking about using thisr adio for that too. OR is the KO PROPO accessory to make the receiver the only way to get 4 channel use?
Thanks again for all the replies.......anyone selling a KO PROPO for a good price.....with a receiver?
DennisNyholm is offline   Reply With Quote
Old 04-17-2002, 06:55 PM   #26
ijnek's Avatar
Smile
i suppose u can use a different brand for the receiver...
but i believe the futaba 3pdf comes with a 3-channel receiver,so u wun b spend xtra on another 3-channel receiver if u get the KO ex-11...
jus a suggestion,...hope it helps u...
Old 04-17-2002, 07:17 PM   #27
Default receiver
I am going to have to buy other receivers anyway, just making sure that the EX-11 will control a Novak 3 channel receiver for my boat. I would use the micro receiver in my xxx-s since I only need 2 channels
Old 04-17-2002, 09:13 PM   #28
Super Moderator
Grizzbob's Avatar
I don't know all the details, but I do know that KO sells some third channel modules that plug into the reciever, & are meant for radios like the EX-11 & EX-1's(though I believe the extra channels on those radios are an on/off thing, not proportional channels). If you look on eBay, you'll seee a number of them appear from time to time.....
Bob Seay
Go Pokes!!!
Old 04-19-2002, 12:36 PM   #29
Default About reciever...
It's correct that KO sells an additional module. Actually, it expand the 2-channel RX to 4-channel.
Personally I'm going the Hitec RX way. I'm probably recieving the HFS-04MI+ next week from my LHS. According to several other people, it should work fine, as long as you stick with single-conversion type RX AND you use KO crystals. But hopefully I can try it out myself in a couple of weeks. Where I live, the Hitec RX is 40% of the price of a similar Futaba RX....
About EX-11 versus 3PDF: The 3PDF also fit my hands better than the EX-11. But only slightly and where I live, the 3PDF are 50% more expensive than the EX-11. In addition the EX-11 got 4 channels, ABS and direct setting. So for me, the choise was easy.
Good luck Dennis, with your TX / RX "hunting".
f/s f-150 pick up 4x4 COOLEY Other Items: For Sale/Trade or Wanted to Buy 0 07-27-2008 06:58 AM
FS:Perfect Futaba radio like new semore R/C Items: For Sale/Trade 6 03-19-2007 10:31 AM
FS:Perfect Futaba radio like new semore R/C Items: For Sale/Trade 3 03-11-2007 03:28 PM
Next pick? Nitroaddicts Electric Off-Road 0 08-05-2006 08:47 PM
You pick which one?? 1st,2nd,3rd or 4th MRIMPACT Australian Racing 31 07-29-2004 02:51 PM
