Futaba micro receiver? >
Old 10-17-2010, 03:52 PM
  #16
Three's Avatar
Originally Posted by SpraydbySprague View Post
Take note, this RX is a 4CH, so it's only compatible with the 4PK and 4PK systems.
If it is compatible with the 603FF and 603FS why can't it be used with a 3PK?.
After all it is a three channel receiver of which we only use two.
Three is offline
Old 10-17-2010, 03:59 PM
  #17
RCknight's Avatar
Yeah way to screw over 3 channel guys if that's the case.
RCknight is offline
Old 10-17-2010, 04:02 PM
  #18
Three's Avatar
Three is offline
Old 10-17-2010, 04:05 PM
  #19
RCknight's Avatar
I'm just saying it's my guess that you can't use the micro receiver with the 3Pk
RCknight is offline
Old 10-17-2010, 04:07 PM
  #20
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by toby333 View Post
Absolutely! Just followed your direction.. They have been slack in that area. I think thats why most of the 3pk/4pk users have bought that specktrum receiver. And its hard to have demand for a product if a brand doesnt even produce it! And why the need for that 3rd channel in 1/10th on road? I reckon just reducing the receiver to two channels would decrease the size....
C'mon get on board!
And that's why I reluctantly switched to the KO Propo Eurus. I would go back to the 4PKS w/o a moments hesitation if Futaba had a micro RX.
JayBee is offline
Old 10-17-2010, 04:15 PM
  #21
Three's Avatar
People.
The receiver is blind, it does not care if the transmitter is 2, 3 or 4 channel. The receiver accepts whatever signal is sent by the transmitter be it 2, 3, or 4 channel.
A 4 channel receiver only means that it can accept up to 4 channels.
Three is offline
Old 10-17-2010, 06:50 PM
  #22
RCknight's Avatar
are you for certain it's compatible? Tech notes only say 4PK
RCknight is offline
Old 10-17-2010, 06:57 PM
  #23
Trader Rating: 8 (90%+)
I would like to know the same thing. What is the smallest rx for the 3pk fasst system?
Tha Skinny is offline
Old 10-17-2010, 07:48 PM
  #24
also is there a difference in the pks fsm orange label and the pkfsm blue label?
The only ifferences i see are the colrs in the labels themselves.
Old 10-17-2010, 08:01 PM
  #25
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
People.
Well, according to Futaba the 4CH RX are not compatible. Check this out.
http://2.4gigahertz.com/receivers/index.html
See the chart at the bottom of the page.
I believe the compatibility problem is the 4CH RX is looking for a signal from all 4 channels of the TX. Even tho we only use 2 channels in most cars, the TX still transmits signal on all 4 channels. If you need proof, just plug a servo into every channel. If the RX does not see a neutral signal on all 4 channels it will not bind.
SpraydbySprague is offline
Old 10-17-2010, 08:50 PM
  #26
secretsg's Avatar
People.
False. While the channels won't matter, 604FS/R614FF receivers have different GUID, and different transmitting mode than the R603FS/R603FF Rx. The 3pk/3pks FASST module only transmit in FASST (C1) mode, and won't be able to bind to the 4 ch Rx.
I have both radios and tested this out already.
secretsg is offline
Old 10-17-2010, 08:55 PM
  #27
Bonadona's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Xpress View Post
Sure thing...........because I want my radio to look like something out of a Power Rangers movie.
+1 Brain.
Bonadona is offline
Old 10-18-2010, 02:34 AM
  #28
Three's Avatar
I stand corrected. Thanks for the explaination.
Three is offline
Old 10-18-2010, 02:50 AM
  #29
RCknight's Avatar
Ok I guess we are back to mass email. lol I agree Futaba's new radio looks mugly. I'll buy a Specktrum before I'll buy it.
RCknight is offline
Old 10-18-2010, 03:27 AM
  #30
R/C Tech Elite Member
Jamison R's Avatar
Are you saying the 4pks is mugly? The KO, spektrum(and even the 3pk) radios are fugly
Jamison R is offline
