Old 10-17-2010, 01:00 AM   #1
Murdock's Avatar
Default Official Team Magic E4FS-D Build & Resource Thread!!
Hey Everyone,
I know there are some other threads reagarding the Team Magic E4D, but I wanted to start a official thread to gather all E4 info into one easy to find thread. I had the lucky oppurtunity to pick up one of Team Magic's E4FS. I will be setting this car for drifting! ROFL. I am calling my creation the E4FS-D! Even tho the E4FS is a foam spec car it has a beefyer carbon chassis, and better arms from what I have read. Very similar to the E4D that is used my Team Hyper Drift in Hawaii, but mine is carbon chassis. Boomba and anyone else that has a E4 info please add your insight here as it comes along. Here are some specs of the E4FS. Most of the car was built besides front bumper and shocks. It has ball diffs front and rear so I will be locking the rear diff.
E4FS Main Features:
* Most lipo battery & brushless motor can be used
* New 3mm carbon fiber, 96mm wide narrow chassis
* New 2.5mm carbon top deck (with two new alum. posts linked to chassis for strength)
* Front/rear 3mm carbon shock tower
* Front/rear hard coated alum. 7075 universal drive shaft
* Alum. 7075 turnbuckles
* New Shocks
* New thickened arms
* New widened belts
* Single bell crank steering system
* Front/rear ball differential (quick release design)
* New lightweight nylon pulley
* Alum. 7075 FF & RR hinge pin mount
* Alum. 7075 bulkhead
* New rear lower Flying Wing arm for foam tires (1 degree toe-in angle)
* New front lower Flying Wing arm
* Centralized motor and battery design
* Quick release main shaft
* Motor cooling mount
* Front/rear anti-roll bar
E4FS Main Spec:
* 1/10 EP Sedan (pre-assembled)
* Width--186mm adjustable
* Length--374mm
* Wheelbase--255~261mm
* 3mm carbon fiber chassis
* 2.5mm carbon fiber chassis
* 3mm front/rear carbon shock tower
* Drive ratio--1.888
* Main gear--116T 64P
* Caster block--6 degree
Team Magic E4 Series
MY Pics of the box and stuff. The packaging is Top Notch!
★ MST: MS-01D Pro
★ Tamiya: TA05VDF, Gold TA05VDF, DF03RA
★ HPI-HB: Pro-D, TC-FD, TCX, Cyclone S
★ Team Magic: E4FS ★ Academy: STR-4 Pro II
★ Yokomo: Hyper SSG DRB, BDM, SD SSG, DP Type B
Murdock is offline   Reply With Quote
Old 10-23-2010, 09:54 PM   #2
Murdock's Avatar
Mounted some Yokomo RS Watanabe 8 Spoke Wheels Black 4mm offset with HPI T-Drifts. Also mounted a Novak 10.5T SS Brushless motor. The rear suspension has the shock standing straight up and down. The front suspension the shocks are laying down. Intercooler is not permanantly mounted. Currently researching Blue Bird servos.
Thanks for looking!
★ MST: MS-01D Pro
Old 02-26-2011, 12:28 PM   #3
phisher's Avatar
Trader Rating: 14 (100%+)
If anyone is interested I have a Dave Ehrlich Team Magic RS4 in great shape with lots and lots of extra parts for sale. I'm asking only $315 shipped. It's posted in the for sale selection with pictures. PM me for details.
www.MichiganRC.net
phisher is offline   Reply With Quote
Old 02-26-2011, 02:23 PM   #4
Trader Rating: 24 (100%+)
Murdock, did you pick up the countersteer kit for it ?? If not, get in touch, I have one I'll never use. It came with a used E4FS I recently bought.
Evoracer is offline   Reply With Quote
Old 06-27-2011, 10:45 AM   #5
str8.krooked's Avatar
possibly buying an E4FS chassis this friday for drifting. looks like a beautiful chassis. I'll be subbing this thread.
WWW.COLORADODRIFTRC.COM
str8.krooked is offline   Reply With Quote
