Cling Film / plastic wrap on tyres? >
Old 10-16-2010, 11:08 AM
Default Cling Film / plastic wrap on tyres?
Ok, so in pictures from national events - cant remember where exactly, if i did I would provide a picture. But they appear to be using cling-film onto of the additive/tyres for the tyre prep.
by cling film i mean, plastic-wrap, Cellophane depending on your nationality.
Has anyone tried this, what advantages did you find.
currently the trend is to use tissue ontop of the additive and then heat.
geubes is offline
Old 10-16-2010, 01:03 PM
Potoczak's Avatar
Trader Rating: 120 (100%+)
I would think they are using the plastic wrap so the tire sauce does not soak into it. Tissue would soak up the sauce.
Potoczak is offline
Old 10-17-2010, 04:12 PM
R/C Tech Elite Member
Jamison R's Avatar
Trader Rating: 64 (100%+)
Cling wrap is to avoid evaporation. Tissue is to hold the prep as close to tire as possible and keeps the prep even all the way around the tire. This has been done in Go Kart racing for years. Heat is obviously to get the prep infaster. Paper towels work better than tissue imho, but use what you have I guess.
Jamison R is offline
Old 10-17-2010, 04:45 PM
Trader Rating: 97 (100%+)
works on kart tires
koz47 is offline
Old 10-18-2010, 03:29 AM
Jamison R's Avatar
Originally Posted by koz47 View Post
works on kart tires
I have been doing this on kart tires for years. Time to try it in RC
Old 10-18-2010, 07:07 AM
Skiddins's Avatar
Normally use tissue, I have only tried cellophane once outdoors and all it did was make the car very slippery (despite removing excess before running).
Perhaps on the water based stuff that is used on carpet it would be of more use as that additive is a lot thinner.
Skiddins
Skiddins is offline
Old 10-18-2010, 07:58 AM
Jamison R's Avatar
Skiddins
Tires cannot be run immediately after removing cling wrap. The tire needs to sit for atleast 30-45 minutes with no wrap, no heat or prep. Reheat tire for 10 minutes (no prep) after the 30 minutes and should be good to go.
Old 10-18-2010, 11:30 AM
Skiddins's Avatar
That's far more time than I want to allocate to tyre prep!
Why not just use the inside of the cups instead of wrap, they are smooth etc?
Skiddins
Skiddins is offline
Old 10-18-2010, 11:45 AM
Jamison R's Avatar
Skiddins
Not something you would use for every race. Its for softening of spec type tires. It brings durometer reading(shore) down and can significantly change a tire depending on chemicals allowed.
