Like Tree74Likes
Schumacher Mi1
Old 08-13-2018, 09:07 PM
  #436
Trader Rating: 15 (100%+)
Asphalt. The track is hobby town USA in Fresno. Seems medium in size.
RBraswell is offline
Old 08-14-2018, 05:43 AM
  #437
Super Moderator
Marcos.J's Avatar
Trader Rating: 199 (100%+)
Originally Posted by RBraswell View Post
Can anyone share with me a base VTA setup for this kit? I am looking to get back into on-road and the sheets on petitrc.com seem a bit dated.
try the base set up schumacher white springs(14lbs) all around , 35 wt shock oil. if you are running asphalt. depending on the grip maybe blue springs front and white rears.
5th wheel likes this.
Marcos.J is offline
Old 08-14-2018, 06:23 PM
  #438
5th wheel's Avatar
base set up is good. 35 wt oil. I run blue 16lb rear and green 18 lb front gear according To your track size.
5th wheel is offline
Old 08-17-2018, 06:52 PM
  #439
5th wheel's Avatar
Brian did you get the axle parts yet for your M I one that I sent you
Old 08-18-2018, 08:09 AM
  #440
ImacFanatic's Avatar
i havent been to the post office in a week or so.
ill go this morning.
ImacFanatic is offline
Old 08-18-2018, 10:02 AM
  #441
cementsurfer86's Avatar
This is a post I made a few years ago. The setup that I posted was in VTA form and will also work for asphalt, but if I remember right, I softened to a AE blue spring front/rear.
theRACERunderground: Turning Venerable into Exceptional: Schumacher Mi1 Build Tips
qcrc and ImacFanatic like this.
cementsurfer86 is offline
Old 08-18-2018, 06:38 PM
  #442
i have parts on back order from Schumacher, they will be in soon but those are in my wish list with them.
thanks for the part #s !!
Old 08-18-2018, 06:43 PM
  #443
build to these specs and itll be great. I am using kit greens and find them to work very well with protoform tires on asphalt. Both shock towers to outer holes 2° toe front and back . 1 1/2° camber front . 2 1/2 rear
i went thru every shock combo and ended up with kit greens 14lb i think . 60 front oil and 40 rear.
.5 mm wider hex shim in rear .
Old 08-20-2018, 06:37 PM
  #444
5th wheel's Avatar
HPI is making VTA tires again
Old 08-20-2018, 06:38 PM
  #445
5th wheel's Avatar
A Main has some in stock
Old 09-12-2018, 06:36 PM
  #446
5th wheel's Avatar
how’s your car running big guy
Old 09-13-2018, 10:36 AM
  #447
car is a beast.
i let a friend use the car for a few heats , he usually runs 17.5 tc , well, he beat me with the Old Mi1 vs my Mi6 lol. It sure aint about how much one spends that makes a better time LoL
Old 09-13-2018, 01:44 PM
  #448
cementsurfer....thanks for sharing your 2014 post. I also have a MI1v2 and am gonna try your thoughts.
ImacFanatic likes this.
Oldrcracer2 is offline
Old 09-28-2018, 05:48 PM
  #449
Hey, No sweat!
I keep meaning to get the car back together and do a bit of an update post. It's still one of my favorite Spec/VTA cars to drive.
5th wheel and Oldrcracer2 like this.
Old 10-02-2018, 06:46 PM
  #450
5th wheel's Avatar
car is a beast.
do you know what oil was in the diffs that I got from you I cleaned them out was very thick was thinking about putting thick oil back in one of them maybe use it on the front thanks Jerry
