Old 10-13-2010, 05:47 PM   #1
Trader Rating: 19 (100%+)
Default Kawada Spur Gears
Hi,
Can someone please help me out by telling me the deal with the Kawada Spur gears? These are the ones in specifically referring to.
http://cgi.ebay.com.au/Kawada-S48-73...item20b2968b52
My questions are the follolwing:
1) What size diff balls are these supposed to use? Some people tell me 1/8 some say 3mm. I have both, and both seem to fall out.
2) On the topic of diff balls falling out, apparently the diff ball holes are kind of one way, so the balls are supposed to fall out one way, and stay in the other way.
If anyone can shed light on this matter for me it would be greatly appreciated.
Cheers!!
Mus
LordAnubis is offline   Reply With Quote
Old 10-13-2010, 06:02 PM   #2
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by LordAnubis View Post
Hi,
Cheers!!
Mus
Looking at my one, it should go in the side where there's no kawada name on it.
defcone is offline   Reply With Quote
Old 10-13-2010, 06:07 PM   #3
Cheers mate, so they are supposed to fall out from one side, and not the other? Also, what size diff balls do you use?
Old 10-13-2010, 06:20 PM   #4
alcyon's Avatar
are u using this for a fixed axle car?
alcyon is offline   Reply With Quote
Old 10-13-2010, 06:29 PM   #5
What's a fixed axle car?
I'm using it in a Tamiya F104Pro. Basically a drive shaft, with two diff plates on either side of the spur, and a nut on the end to tighten/loosen the diff.
Old 10-13-2010, 07:34 PM   #6
defcone's Avatar
I think it was 3mm, yeah a 12th scale.
Worn out Spur Gears peterchia41 Electric On-Road 23 08-06-2008 05:48 AM
tc3 spur gears dynamaxxed Electric On-Road 6 04-28-2005 03:53 AM
Xenon Racing Spur Gears dontfeelcold Electric On-Road 36 06-09-2004 07:03 AM
