Old 10-13-2010, 01:01 PM   #16
Foxxrocket's Avatar
Originally Posted by Rick Hohwart View Post
This is how I do it and it works like a charm. Only problem is that sometimes with TC you don't want perfect circles.
Yep, sedans have a horseshoe shaped wheel well. So, you just use the cutter for the circle and some regular scissor to taper the ends. Then use 150grit sandpaper to make it all flush.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 10-13-2010, 01:03 PM   #17
odpurple's Avatar
Originally Posted by bionictony View Post
just use the circle cutter and score it about halfway through with the sharp blade.. then rip the lexan out. you do not have to cut through the lexan. once it is scored, then it will tear at that spot.
+2
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 10-15-2010, 07:57 AM   #18
oldpugva's Avatar
Arrow
+3 - this works like a champ!
<Straights are Easy>
| AE | LRP | Tekin | Spektrum |
RCRNV Twitter |RCRNV Web |RCRNV Facebook |
oldpugva is offline   Reply With Quote
Old 10-15-2010, 08:09 AM   #19
JRXS_chris's Avatar
1. Paint body
2. Mount body
3. Dab grease on to the wheel shafts and push the shell against it.
4. Un-mount body and either use a Wheel Compass point on the grease or create a centre point using a reamer.
5. Get a glued wheel/tyre and line up centre point with the hole in the middle.
6. Draw round wheel against bodyshell.
7. Cut out using curved scissors or preferred method.
I can't stand wheels not mounted correctly in the shell!
JRXS_chris is offline   Reply With Quote
Old 10-15-2010, 08:17 AM   #20
Originally Posted by JRXS_chris View Post
1. Paint body
2. Mount body
I use a similar method but I paint the body last that way I can see through the body where the cut outs are to be.
AreCee is offline   Reply With Quote
Old 10-15-2010, 09:29 AM   #21
I score the wheel well with a new xacto, then use my lexan scissors to make pie cuts up to the scored area, then snap it out. Go back and touch up with a sanding drum on a dremel, but that's rarely needed. You can cut nice curves with this method. If you want, trace what you want for the wheel well out, then score your trace. Once lexan is scored it will snap on that line.
markw is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 46174 Today 10:07 AM
