17.5 Brushless Motor >
Old 10-12-2010, 03:25 PM
Default 17.5 Brushless Motor
Which has a better overall performance Tekin Redline 17.5t or Speed Passion
Competition V3.0 17.5R on-road brushless motor?
Geiger is offline
Old 10-12-2010, 04:33 PM
Bubblehead's Avatar
My Redline was slow, and there's one other driver using one and he's slow all other are using BOSS Speed Passion or LRP.
Bubblehead is offline
Old 10-12-2010, 06:05 PM
RDOUBLEDAY's Avatar
out of them two the speedpassion, But if you want a awesome motor, Go with murfdogg or epic duo2
RDOUBLEDAY is offline
Old 10-13-2010, 09:18 AM
How about incoming Epic Duo3 17.5?
Geiger is offline
Old 10-13-2010, 09:46 AM
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
no one knows there not out yet
20 SMOKE is offline
Old 10-14-2010, 01:05 AM
Which ESC is best for BOSS motor? LRP SXX TC Spec Version 2, Tekin RS Pro, Speed Passion GT2.1 EX?
Geiger is offline
Old 10-14-2010, 01:08 AM
Which is better motor Murfdogg or BOSS motor?
Geiger is offline
Old 10-14-2010, 02:37 PM
Bubblehead's Avatar
I would go with a Tekin RS, the difference between the RS and RS Pro is motor limit (RS 5 turn Brushless, 8 turn Brushed Fwd mode, 10 turn Brushed Fwd/Rev mode) Pro no motor limit. You can also use Tekin's Hot Wire to update your ESC.
Old 10-15-2010, 07:52 AM
oldpugva's Avatar
Arrow
That's a loaded question - depends on the driver. Looks like you are just getting started. Recommend you go with whatever brushless motor you like (good choice with brushless). Get a good ESC - I prefer Tekin RS. Gives you a LOT of control with or without the Hotwire (recommended) and room to grow when you are ready to move up.
oldpugva is offline
Old 10-15-2010, 08:30 AM
I wouldnt say the Tekin 17.5 is slow. Mine is fairly quick when I use it.
Something I really like with the Tekin Redline motors is they're sealed pretty well so if you run on a less than a perfectly clean track or are bashing they don't require as much maintenance as one of the motors that has openings on the can or exposed bearings. Pretty much the only maintenance that needs to be done on a Tekin motor is to pull the front off and clean and lube the front bearing and you're good to go again. I tried a Duo 2 for a short time and the amount of crud that motor collected inside in the short time was amazing.
spongerX is offline
