Old 07-01-2004, 02:25 PM   #1
Send a message via AIM to LancerEVO
Default gearing
Does anyone know the best gearing for a tc3? the gearing i have right now is
27 T Pinion
72 T Spur
LancerEVO is offline   Reply With Quote
Old 07-01-2004, 02:44 PM   #2
Need to know what motor and tires
1/8 Scale: Tekno EB-48.2... Tekin RX-8 GEN-2 W/2050kv... Airtronix M11-X Radio... HiTec HS-7954SH Servo...
1/10 Scale: Associated B-5(rear motor)...Tekin RSX Gen-2 W/8.5t... Savox SC-1258-TG Servo
Joe B is offline   Reply With Quote
Old 07-01-2004, 02:47 PM   #3
if it's the AE 19 turn you have under your post ......thats pretty close for that motor......mabe try a 26
Old 07-01-2004, 11:17 PM   #4
Post
yes try around a 7.0 final .. what would be close is like joe said a 26 pinion ,, or you can try in the mid 6's ive had very good luck.. also make sure of track situation .. sweeping , or tight track and adjust as needed ..
Mark Barden .
mb racer is offline   Reply With Quote
Old 07-01-2004, 11:22 PM   #5
howard hudson's Avatar
R/C Tech Charter Subscriber
Default reedy
If you have the REEDY 19t #513 quad magnet at the Reedy Race we were running that motor around 5.7 If your running stock it depends on which motor your running 7.0 is a good place to start. you can also check out the other forums on this site ie the stock motor forum and the 19t forum
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
Old 07-01-2004, 11:24 PM   #6
CA$H's son's Avatar
Send a message via AIM to CA$H's son
if your running a monster stock a 7.0 to 7.5 ratio is always nice with the TC3
CA$H's son is offline   Reply With Quote
Old 07-09-2004, 11:53 AM   #7
Hey guys,
I have a xxx-s gp with a reedy 19t quad mag. Our hobby shop has a small 50 x 30 carpet track. Right now I am running a 90t spur and an 18t pinion 48 pitch. How should I gear this thing? So it's not too hot but still maintains it's performance?
PSI Racer is offline   Reply With Quote
Old 07-09-2004, 12:40 PM   #8
Regional Moderator
UnderDaHill's Avatar
Send a message via AIM to UnderDaHill
For the Reedy Quad 19t on a small track I'd go with about 6.5 - 7.0 final drive ratio (that's 6.5 - 7 turns of the motor to rotate your tires once). I'm running a 100spur with 41 pinion on my tc3 on a 94'x40' track. It's probably not as technical as yours so I can gear taller (taller = smaller ratio number). I'm also using 64 pitch gears. My tires are also 60mm right now... as they get smaller the raitio I run drops below 6.0.
If you are using a 90 spur and 18 pinion your final drive ratio is like 12.5. Your motor probably raps out almost instantly. You are WAY under geared. BTW... a motor can get pretty hot when undergeared that far.
Try a 32 pinion and then go up or down based on your lap times. The 32 gets you to a 7.0 final drive ratio. Your track may be technical enough that you'll have to go up more than that but I can't say without seeing the layout. I wouldn't think you would ever need to go over 7.5 with a reedy quad 19t motor since they have WAY more torque than most other 19t motors.
Hope that helps.
UnderDaHill is offline   Reply With Quote
Old 07-09-2004, 06:04 PM   #9
Hope that helps.
Thanks for the info...I'll try it out.
Old 07-13-2004, 06:50 PM   #10
Hope that helps.
Thanks man. The car seems faster and isn't as hot. I'll shoot the temps out in a couple of days. Do you know where the temps need to be?
Gearing lickashotblaow Electric On-Road 0 07-29-2007 05:47 PM
NeeD Help with gearing please daver1 Electric On-Road 4 07-20-2007 09:12 AM
Gearing for TT-01 tl-01-jhb Rookie Zone 0 11-10-2004 05:35 AM
Need help gearing a TC3 fasda1 Electric On-Road 10 11-06-2004 11:51 AM
Gearing??? mike m Monster Trucks 3 01-24-2004 07:54 PM
