lipo help
lipo help
I have a Intellect 7.4 50C battery. I cannot seem to balanced charge it at 5 amp. I use a hyperion charger. Any ideas?
Thanks in advance.
Thanks in advance.
Why won't it charge? Does the charger just stop prematurely or does the battery just not take a charge? What size (mah) is the battery?
Maybe its the charger... have you tried to charge a similar battery at the same Amps... I would try another battery to see if its a problem with the charger or the battery.. Also try charging the battery on another lipo charger and see if it will take the 5amp charge.
