Old 10-07-2010, 02:11 AM   #1
AndiF's Avatar
Default Pan Car/World GT wheel hubs for F103/F104
Always wanted to convert your F103 or F104 to a World GT/Euro GT racer?
Here's the solution to it: Pro10 wheel hubs for the F103/F104, machined from T6 7075 Aluminium.
With these, you can use all the great wheels made for Pro10, World GT and other 10th pan cars from BSR, CRC, Jaco etc.
The hubs will provide a width of approx. 195mm and can also be used on F1 cars, if a narrow rear wing is mounted.
The hubs come in a set containing 1x left wheel hub, 1x right diff hub and 1x special belleville washer.
Price for this set is CHF 77.90 / EUR 60.- / US$ 77.-
Shipping to the US is US$ 12.-, to Europe EUR 8.-
The hubs can be ordered through email: [email protected]
Payment can be made through telegraphic transfer or paypal.
To finalize the rear end of your F103/F104 with these hubs, besides the rear axle itself you need the following additional parts (NOT included with the hubs):
2x 8x12mm ball bearings
1x Tamiya 51233 F103GT diff holder & spacer
1x Tamiya 51230 gear bag (thereof you need only G1 'differential housing B')
1x Tamiya 51346 diff set (thrust bearing and belleville washer)
1x Tamiya 51347 diff plates inkl. 3mm balls
1x M4 lock nut
1x Tamiya spur gear with 8x12mm ball bearing
-> alternatively to the Tamiya spur gear: commonly used 48dp or 64dp spur gears with spur adaptor ring (eg 54215 spur gear adapter) and 1/8" diff balls(attention! 3mm diff balls from Tamiya do not fit!)
-> alternatively to the G1 diff housing made of plastic you can use the aluminium version: 54082 F103 Aluminium diff housing
For the front end, you can just use F1 steering blocks with corresponding ball bearings, or (this is what I recommend) you can use the Xray steering blocks and wheel axles. These are made for 3mm king pins but do feature a 1/8" wheel axle, so that the usual front wheel ball bearings can be used.
In either cases you have to remove some material from the lower A-Arm in order to free up the front wheels (all these items have to be purchased separately).
For any questions, pls email me ([email protected])
Have fun
Andy
Pan Car/World GT wheel hubs for F103/F104-imag0134.jpg   Pan Car/World GT wheel hubs for F103/F104-imag0135.jpg   Pan Car/World GT wheel hubs for F103/F104-imag0136.jpg   Pan Car/World GT wheel hubs for F103/F104-imag0150.jpg   Pan Car/World GT wheel hubs for F103/F104-imag0154.jpg
Team Durango Switzerland - Corally - CRC - IRS - Team Associated
AndiF is offline   Reply With Quote
Old 11-23-2011, 12:59 AM   #2
AndiF's Avatar
Dear all
Only 4 adapters left.
Due to the actual exchange rate situation, the prices have changed dramatically. The mentioned CHF 77.90 above were the introduction offer, the actual price is CHF 84.90. Based on this, the new prices are:
CHF 84.90 / EUR 69.- / USD 94.-
Shipping (economy & registered) to the US is USD 20.-, to Europe EUR 15.-
Pls order through email ([email protected]). First come first serve.
The new batch of adapters is planned but still not confirmed.
Rgds,
Andy
