TC3 Rattling problem
Hello i was racing my car yesterday at hobby world and my car just started making a wierd rattling noise does anyone know whats wrong? ill try and record the sound
the noise seems to be coming from the front of the car
Could be the differential. If not that I would just check to make sure all the screws are snug.
its best to open up the gearbox and check the diff and input shaft, then the laft and right drive shafts and bearings to locate the problem, so see if it still makes the sound without the cvds/dogbones installed so u can be sure where its from
Re: TC3 Rattling problem
Check the CVD's and open the diff casing
its not the diff's ive checked them i think its my steering blocks because they wobble and i cant stop them from wobbling ive put new steering blocks but they still wobble
and ill be at hobbyworld i think Friday , saturday , or sunday
noises..
also check the drive cups for the shaft .. if there worn thell do just that and make noise .. other than that if your running the losi front hub's they might be binding at full lock causing the cvd's to bind and could result in replacing the wheel bearings .. my 2 cents.. good luck !! one more thing replace the ball cups if worn too ..
Where in SJ do you live...The chances of me being there this Saturday are slim (no cash) but I'll be at Sheldon's on the 10th
I shot you a few e-mails
do you have AIM?
