Old 10-05-2010, 07:08 PM   #1
Default Brushless ESC for flywheel only?
Hi,
I'm working on a gyro project that uses flywheels at high RPM.
I've heard that RC car ESCs should be a better choice over heli ESC for starting torque, but I am not sure which one is the most suitable. Sites like HobbyKing have a hundred to choose from.
Do car ESCs do high RPM under no load? I'm looking for:
-torque start (dont care how slow it starts)
-high max rpm
-doesnt need a high amp rating
I have a helicopter ESC which runs the hard drive motor fast, but will not start with a heavy wheel attached.
Any advice on which ESC to get would be much appreciated.
jaz_werk is offline   Reply With Quote
Old 10-05-2010, 07:12 PM   #2
how much it weighs
xxx4 g+
Team Yuntong
duratrax 8t pro
spectrum dx2.0
dgaumond is offline   Reply With Quote
Old 10-05-2010, 07:26 PM   #3
Well I'm not too fussed about the exact weight of the flywheel, but I'm thinking the size will be about 500g, 5cm diameter.
Old 10-05-2010, 07:35 PM   #4
wingracer's Avatar
Trader Rating: 24 (100%+)
You're probably going to want one with a bit more amp ability. The constant current might be low but that initial start-up can be brutal.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 10-06-2010, 11:17 PM   #5
So how do I know which motors have an RC car suitable (some torque plz) startup? Every shopping site I browse just assumes you are looking for plane/heli ESC.
Old 10-07-2010, 05:41 AM   #6
i tested few esc with 1.5lbs and if you can have align 35A car this esc start any load ultra smooth
i don't know if flying esc work also but the startup firmware is very good in this brand
xxx4 g+
Team Yuntong
duratrax 8t pro
spectrum dx2.0
Lots of stuff for sale Squidward R/C Items: For Sale/Trade 58 06-27-2010 09:20 PM
Novak Sentry as Brushless Dyno mattnin Electric On-Road 132 01-29-2010 05:53 PM
Losi eight 2.0 W/losi brushless conversion russo11218 Electric Off-Road 10 11-13-2008 08:33 AM
