Old 10-04-2010, 04:55 PM   #1
Default Solder Brushless Motor
Just got my first brushless setup. Can someone give me some tips for soldering the tabs? I am sure there is a trick too it and I want to get it right. Thanks.
AE SC-10
HPI Blitz ESE (17.5 ROAR)
HPI Blitz RTR
HPI E-Firestorm
Traxxas Stampede
Chip73 is offline   Reply With Quote
Old 10-04-2010, 05:29 PM   #2
Plug in soldering iron, allow to heat up, tin the wires and tabs, apply the iron to wire and tab, allow to cool, go to the next one.
What is it that you need to know?
AreCee is offline   Reply With Quote
Old 10-04-2010, 05:56 PM   #3
Do I stick the wire through the hole and solder on the all metal side or just solder right to the all metal side like a battery tab?
AE SC-10
HPI Blitz RTR
HPI E-Firestorm
Traxxas Stampede
Old 10-04-2010, 06:00 PM   #4
Regional Moderator
CarbonJoe's Avatar
Both ways work. Smaller gauge wires fit through the holes easier.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 10-04-2010, 06:32 PM   #5
Yeah, either way works. Just make a good solder connection.
Old 10-04-2010, 06:58 PM   #6
But don't overheat the tabs
John Warner is offline   Reply With Quote
Old 10-04-2010, 07:17 PM   #7
JKL1031's Avatar
I but mine through the tabs, and i think you should
China Lipos
China Speedos
China Chargers
You aint messin wit my dougie..
JKL1031 is offline   Reply With Quote
Old 10-05-2010, 03:09 AM   #8
Default Tabs
I do mine on top for a cleaner joint, on most motors the holes are large so wire is a bit sloppy in hole so top is best for me.
Another idea is to take a dremel to the tabs and cut across the hole so you left with a half moon makes soldering now very easy. HTH
MB Models Leeds,RC4LESS,Troy McKune
V-DEZIGN CR5 ,LRP SXX, CRC cells,
tellan is offline   Reply With Quote
Old 10-05-2010, 04:49 AM   #9
As was said before don't leave the iron on the motor solder tabs too long. Those tabs connect to a circuit board in the motor that you can damage with too much heat.
Easiest way to do it for me is to tin the wires. Tin the tabs. Then solder the wires to the tabs. Be careful to avoid drips between the tabs. If there is a connection between the tabs you will have problems running the motor.
If you're using thick wire like 12 gauge you'll need a good hot iron. 80w or more I'd say. I've tried it witha a 40w iron before and while it sorta worked the solder didn't get very good penetration in the wire when tinning it. A more powerful iron makes it easier.
spongerX is offline   Reply With Quote
Old 10-05-2010, 09:33 AM   #10
JKL1031's Avatar
Can I. See some pix on solderin ontop of the tabs.
China Lipos
China Speedos
China Chargers
Old 10-05-2010, 10:57 AM   #11
+1, so far good information, thanks allot. Pictures would seal the deal for me.
AE SC-10
HPI Blitz RTR
HPI E-Firestorm
Traxxas Stampede
Brushed, Brushless, Motor Freezers, Dischargers, Team Much More & more (New & Used) F. Mendoza R/C Items: For Sale/Trade 86 03-21-2008 08:37 AM
Brushless Motor Thread RC Buddah Electric On-Road 261 08-30-2007 03:42 PM
Brushless Motor FAQ syndr0me Electric On-Road 25 08-07-2006 08:31 PM
