ESC and motor compatibility >
Old 06-30-2004, 09:08 AM
Default ESC and motor compatibility
Hi there,
I have been told by my LHS that if I was to purchase a trinity monster pro for my R/C car i would need a 'competition' spec ESC for it????
Is this correct or is he trying to get more money outta me than he should???
vala is offline
Old 06-30-2004, 09:50 AM
new92's Avatar
I am pretty sure that any ESC out there will handle a stock 27turn Monster.
There is a guy like that at my LHS. I was in there one say pciking up an order and overheard him telling a guy that had just bought an Evader so much BS that I actually waited outside for 15 minutes until the guy came out and tried to give him more accurate info.
new92 is offline
Old 06-30-2004, 01:22 PM
cheers for that, thought it sounded a bit suspect.
looking to get a nosram esc for my r/c car, but just need some advice as to which one to get. i don't wanna go for the magnum reverse as I have just bought that one and its causing me endless problems, so looking to exchange that for a different one.
I would like an ESC which has forward and reverse.
Any suggestions???
vala is offline
Old 06-30-2004, 10:27 PM
vala, if you can wait I would look into the new XRS ESC from Novak, nothing but quality from Novak. BTW, Nosram and LRP are both the same-just in case you didn't know.
http://www.teamnovak.com/products/esc/xrs/xrs.html
ZER01 is offline
Old 07-01-2004, 12:56 PM
Cole Trickle's Avatar
Any suggestions???
In general, I'll suggest you stick with an ESC from a wellknown brand like LRP, Nosram, Futaba, KO Propo, Keyence, GM or Novak.
It depends a little on what you want to do.
If you want to race, a reverse ESC have higher internal resistance, which means less volts for your motor, thus less speed.
Also, for racing it's good to have a fast steering servo. Many low-end to mid-range ESC, only deliver 5 volts for the servo. Since most servos is designed for 6 volt, such an ESC will give you a 25% slower steering servo.
There's 2 ESC's, which fullfill these requirements for a reasonably price. That's the Hitec HFX and the GM V8. The GM even is programmable, though it's not the easiest to programme. Ths GM is what I would go with, if it's for racing on a reasonably budget.
If it's for bashing, you might consider a brushless. No maintenance, and lots of speed and run time. Even a 27T stock motor needs maintenance with comm cutting and new brushes, so in the long run the brushless system is cheaper. Especially, if you dont have access to a comm cutter.
Cole Trickle is offline
