Old 06-29-2004, 03:29 AM   #1
Default Xenon inserts
Who knows the difference between the differents Xenon inserts:
-XENON MOLD TIRE INSERT
-HI-COMP MOLD TIRE INSERT
-X-TYPE MOLD TIRE INSERT
Hugo is offline   Reply With Quote
Old 06-29-2004, 03:37 AM   #2
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Xenon inserts
Sure do...to some degree..
the regular molded insert is about 4.5mm tall and has a normal shaped bottom or section that touches the rim
the Hicomp is 4.8~4.9mm and basicaly fills the gap in the tire..I.E. a solid feeling tire.
and the X-type is 4.3~4.4mm and has a very narrow bottom where it makes contact with the rim and they have a tappered top..(which I think give your tires a weird wear pattern )
now as for how they work thats a different Question
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 06-29-2004, 04:06 AM   #3
Thanks a lot Dave, very good answer.
Regards
hugo
Old 06-29-2004, 05:33 AM   #4
As regarding traction and tire wear, is it better to have a solid feeling tire or with a little gap?
dhiracing.com is offline   Reply With Quote
Old 06-29-2004, 05:37 AM   #5
It all depends on what your track conditions are like...
-Dave
Old 06-29-2004, 06:19 AM   #6
Hi Dave,
In Malta, we have a large asphalt track outdoors with high frequency small bumps. Any suggestions?
Regards,
Mark
Old 06-29-2004, 06:32 AM   #7
Hi Dave,
Regards,
Mark
I would try the X-Type series..
Aqua=Soft
Black=Medium
Gray=hard
I prefer them better than the other 2 types..
-Dave
Old 06-29-2004, 08:27 AM   #8
Matt Howard's Avatar
I've had good luck with the X-type Grey and the hi-comp Reds in my sorex 36's with track temps between 110-150. I think the Reds were slightly better when the track got closer to 150 and the greys were slightly better when the track was closer to 110
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 06-29-2004, 11:59 AM   #9
Neil Rabara's Avatar
The black inserts were quite soft on a high traction traction. Perhaps the greys would work better. I traction rolled on asphalt with the black inserts.
Neil Rabara is offline   Reply With Quote
Old 06-29-2004, 12:42 PM   #10
Default Sorex 32
In the French championship we are allowed to use (only) Sorex 32R, do you think that the X type Grey is ok?
What do you advise me to use?
Old 06-29-2004, 01:13 PM   #11
Default Re: Sorex 32
The greys are one of my favorite inserts and they should work fine in the 32's
RCTech #361
Old 06-29-2004, 02:08 PM   #12
Thanks a lot Matt,
Do you advise me to use Hard, medium or soft wheels?
Which ones do you use?
Do you use tire additive with Sorex tyres, if yes, which one?
Old 06-29-2004, 02:22 PM   #13
Thanks a lot Matt,
I always use the Sorex dish rims which are probably the stiffest rims on the market. I've tried different additives on the sorex tires but I could never tell a difference. I've heard of people using paragon with success on some tracks.
RCTech #361
Old 06-29-2004, 03:19 PM   #14
FXII and a little tire warmer action... works great with SOREX tires.... Well most do..... one pack specials (AKA 24R's don"t work to great with the sauce )
-Dave
Old 07-10-2004, 02:18 PM   #15
TC3
TC3's Avatar
do xenon inserts work in cs27?
cs27 like low profile inserts
which xenon insert is the right one for meium grip asphalt? with cs 27..
TC3 is offline   Reply With Quote
Xenon or Xenon R Cooling heads WANTED Paulie Bee R/C Items: Wanted to Buy 0 07-23-2008 05:40 PM
Xenon or Xenon R Cooling heads wanted Paulie Bee R/C Items: For Sale/Trade 0 07-23-2008 05:39 PM
Tires / inserts / wheels HPI yokomo Xenon calstarjig90j R/C Items: For Sale/Trade 9 12-23-2006 07:10 PM
Xenon tunnelhead Electric On-Road 7 11-10-2005 06:31 PM
