Has anyone tried fountain syrup?
I realize that the reason root beer or whatever cola product works better than just sugar water is because it dries to a sticky syrup instead of drying to crystalized granules, but has anyone ever just gotten a bag of the syrup for a fountain drink machine, mixed it with some water and sprayed it out of a sprayer? From my experience a regular sprayer doesn't work well with sodas because of the carbonation.
Thanks for the info...
I don't think you can buy the actual syrup with out being a resturant or some sort like that... but you could probally take some drinks and let them sit out for a little bit till they get flat...
Location: Built By The Racers For The Racers. Corona CA
We tried it here in Southern California. It worked great in the cooler months. I would not use it though if track temp gets to high. We hit a track temp of 160+ and the traction was gone. The syrup melts and the tackiness is gone!!!!
We were able to use a regular Hutson Sprayer with no problems.
Im pretty sure we used that one time. It worked great during the day but as soon as night time rolled around it started sticking to the tires and resulted in zero traction.. It was a pain...
We used everything from grape soda, snow cone syrup to VHT. It was a constant fight to get traction at one of our locations. We found out the asphalt was just to old and no matter how good we cleaned or sprayed, after about 25 minutes of racing a black dust would appear. It was the asphalt breaking up.
Our other location needs no treatment, we are lucky to have school grade (name) asphalt that provides the best consistant traction.
If you have to spray, I would reccomend what we call the Fred Hubbard mix, Grape Soda and Grape Snow Cone Syrup, it is sticky as hell!
Originally posted by racenut123
What do you guys use in the heat RCHeat?
Originally posted by R/C HEAT
Sorry, didnt read it right, the best thing to use in the high temps is VHT, you can cutt it with Methonal to make more.
THIS IS EXTREMELY FLAMABLE THOUGH while spraying
At Tamiya they have found PANCAKE Surup works great and it smells good in the morning too
LOL- thanks for the tips. And the jokes...
BTW- I come from drag racing, and you need to be cutting your VHT with mineral spirits. Regular old paint thinner grade mineral spirits. You should also clean your sprayers ASAP with mineral spirits after spraying. Anything else will either be too dangerous or ruin the composition of the VHT.
At my local track they spray it down with a mixture of sugar water and mountain dew and it works good.
Tim
Don't use a sprayer....Do it NorCal style
Poke a hole in the bottom of the bottle. Faster, cheaper and works
Well, not if you do it right. You don't just set the bottle down and walk away like a numbnuts...lol
I use to work at Pepsi Cola. Anyway's the stickiest drink out there is Hawaiian Punch. When that stuff use to spill in the warehouse it would take your boot right off your foot. I don't know how good it would work on a track Because my local tracks use VHT and Rootbeer.
