Old 06-27-2004, 08:47 PM   #1
Timmy_G's Avatar
Send a message via MSN to Timmy_G
Default Tyres and Carpet Racing
Hey all,
A friend and I are throwing up idea's of a control class with the idea being having a class which costs stuff all to run in. Cheap on motors and tyres.
We are currently sourcing some carpet suitable to race on for the location we already have sorted out, but... Im just wondering how tyre wear is on carpet? What works?? foams, rubbers, and what compounds? And in which class were you running when you came across you're verdict for how long you're tyres last.
Any comments are greatly appreciated.
Tim
Losi, JR Propo ,Spektrum, Novarossi, AT Racing Fuels
Timmy_G is offline   Reply With Quote
Old 06-27-2004, 09:22 PM   #2
F1Junkie's Avatar
R/C Tech Charter Subscriber
Hi -
I know foams will almost always work on carpet - it just depends on how soft a compound you want to run - which will affect how quickly the tires go down. If people at your track have tire truers, great!
As for rubber - most people at our track run Take-Off CS-22s - they are the softest from this company. The are reasonably durable and do the job most most everyone...
My $0.02
Cheers
Dave
F1Junkie is offline   Reply With Quote
Old 06-27-2004, 09:36 PM   #3
Super Moderator
Grizzbob's Avatar
True, foam tires will have the most grip on carpet, but they also wear out a LOT faster than rubber ones(& you usually have to have a tire lathe available so they can keep them running true, & they also have to change their gear ratios as the tires wear, so their cars' rollout will stay the same as the tires wear). But rubber tires should work just fine on most carpet, & a good choice for a spec-type class is TakeOff's premounted ones, in either CS-22 or CS-27 compound. The CS-22's will grip better, but will wear a bit faster than 27's do. If you can get enough traction from 27's, I think those are what I'd reccomend, because you could probably run for a couple of MONTHS on 2 or 3 pairs of them before they might need to be replaced(& that kind of low wear is hard to beat for the price). plus, the best thing about the TakeOff premounts is the price, in my area, we easily see full sets of them(4 tires, with inserts, already mounted & glued on decent wheels) for about $35US, which is pretty hard to beat by anyone....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 06-28-2004, 12:08 AM   #4
fatdoggy's Avatar
Side note - Rubber tires will wear out the ozite faster then foams.
fatdoggy is offline   Reply With Quote
Old 06-28-2004, 02:04 AM   #5
Timmy_G's Avatar
what compound rubber? or 22's or even the 32's wear faster... if you can get them to work?
Old 06-28-2004, 02:12 AM   #6
fatdoggy's Avatar
Is this carpet or Ozite?
Old 06-28-2004, 02:13 AM   #7
Timmy_G's Avatar
we are more likely to be running ozite.
Old 06-28-2004, 02:27 AM   #8
fatdoggy's Avatar
Just thought I ask since a track up in brissy runs carpet.
I've run Sorex 36r's on ozite and they hook-up surprisingly well, a little too hard(I'm sure I could get 32r's to work fine at my local track). Kind of funny really you can get the squeal of rubbers on high grip ozite. They were soaked with compound for a long time; wear on them didn't seem too bad at all. If you don't want to mess with stinky compound then stay with the softer tires (27-22). Rubber on ozite will last quite a while anyway.
Old 06-28-2004, 04:58 AM   #9
Cole Trickle's Avatar
On our carpet track, CS-22 cant get grip, unless you use traction sauce - which aint allowed here I dont know which kind of carpet we use, but we have quite low temperatures during the winther, just something to consider.
If the purpose is to keep it simple, to get as many as possible into the class, I would stay with rubber and forbid the use of traction compound.
At several carpet tracks in our area, many of us have good results with M1 tires. GM market them. Grip is good, but the wear could be a little better.
Also consider Schumacher Dragon carpet tire - very good grip in many cases and with a reasonably wear. With this tire, we actually have problems with traction rolling, is the inserts are too soft.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 06-28-2004, 05:02 AM   #10
Default Tire wear
Some time ago, I did a test. It was with the discontinued Schumacher White, which is a slick tire. Without belting them, they lasted approx. 25 runs, before you could see the insert. When I belted them with gaffa tape, they lasted approx. 50 runs, before insert was visible.
Old 06-28-2004, 06:45 AM   #11
DerekEngland's Avatar
Send a message via AIM to DerekEngland Send a message via Yahoo to DerekEngland
When we were running on carpet we ran pit 20s and 24s. The wear was really pretty good.... you could get about 3-4 months out of a set.... The foams get a lot more grip but they can be chunked pretty easy.... So if you want to keep the long term cost down use a rubber tire.... If you want performance then use a foam tire....
My $0.02 is now at a discount.... $0.005 is about all it's worth....
Schumacher USA
R/C Paints by Sonny
DerekEngland is offline   Reply With Quote
Carpet racing with rubber tyres A Ilievski Electric On-Road 11 08-22-2008 07:42 PM
Horsham R/C Racing '06-'07 Winter Indoor Carpet Racing Travis Repp Mid Atlantic RC Racing 0 10-22-2006 05:38 PM
UFRA Racing Tyres Davo Australia For Sale/Trade 0 07-13-2006 10:28 PM
Which Tyres for Carpet inet-projects Rookie Zone 3 02-08-2006 12:00 PM
Medial Pro racing tyres - where in oz? au_Nightmare Australian Racing 1 03-17-2003 09:20 PM
