Old 09-23-2010, 10:55 PM   #1
Default Tamiya - M-03, M-04, M-05 - Whats the Difference?
Hi All,
Just wondering what is the difference between Tamiya's
M-03, M-04 & M-05 kits ?
I noticed engine placement is different across some of them....just wondering what exactly are the differences? and what do the differences change in terms of handling/performance?
Im looking to possible get one of these kits and was wondering what the differences are.
Cheers,
Martin
halo123 is offline   Reply With Quote
Old 09-23-2010, 10:59 PM   #2
ZiG-87's Avatar
m03 is fwd and top heavy. m04 is rwd and has a lower CG. Can also fit a bigger pinion. m05 is fwd again and has a lower still CG. Most people feel that the m05 is the superior vehicle, however I am personally a fan of my m04. In a club race in my town, most of the a-main is m04's.
ZiG-87 is offline   Reply With Quote
Old 09-24-2010, 01:29 AM   #3
tony gray's Avatar
Halo, I think you'll find that 98% of clubs around the world do NOT run M04's. Nearly all M-chassis racing is FWD only which is M03 or M05.
Despite what many people will try and tell you one is not faster than the other (05/05). They are both capable of identical lap times.
M03 is easier to work on than M05, but M05 is newer, hence some people prefer it.
We run both successfully.
tony gray is offline   Reply With Quote
Old 09-24-2010, 04:33 AM   #4
SteveM's Avatar
Trader Rating: 142 (100%+)
The M-03 is a very easy car to wrench, while the M-05 is less so. The M-05 seems to have more adjustability with shock position and such and it does have a lower center of gravity. I'm still running the M-03 and doing pretty well in club racing.
SteveM is offline   Reply With Quote
Old 09-24-2010, 05:05 AM   #5
Thanks for the replies ....
these both seem to be going for about the same price, so would i be getting more bang for my $ getting the m-05 as it is newer?
mainly this is for street use/bashing...also are these equivalent to the HPI cup racers? and if so, what is the difference? and which is better?
thanks again
Cheers
Martin
Old 09-24-2010, 05:48 AM   #6
SteveM's Avatar
If you can find the 5 for the same price as the 3 then it's probably best to get the 5. Check what upgrades may be included when buying used as the base kits are pretty basic and most guys add option parts like oil shocks, ball bearings, etc...
The HPI car is 4wd and you really can't compare against the 2wd Tamiyas. If you want to wait, Tamiya will be releasing their new M-06 rwd mini sometime soon and it may be worth the wait. Time will tell though.
I'm also putting together an Xevo mini from the spare parts in my pit box. There is a separate thread here on RCTech you can check for more info.
Old 09-24-2010, 02:28 PM   #7
superspeed's Avatar
Wait until M06 Pro comes out, it has a tub chassis. I'll be getting one. Currently, I'm running M05 Pro. They just did a blue plated version for the M05 Pro.
http://www.tamiyausa.com/product/ite...oduct-id=84131
superspeed is offline   Reply With Quote
